I have an Viewsonic VW2010wb-EU (Modell No. VS11674). If I connect it to 230V-net only the LED lights orange (duo-LED, amber and yellow lights). It doesn't react on any key. So the light is permanantly on.
The caps of the powersupply was swollen. The transistor Q5 and the stepup-controller U6 are realy hot. The PC recognize the display correct.
I have done the following things to repair it:
-change all caps of the powersupply (see picture, same capacity and voltage, low esr type, bought from local seller, i don't know which brand they are) -> powersupply seems to work ok now
-change of the transistor Q5 -> no effekt
-provide the 5V power over an external powersupply -> the same error as befor
-disconnect the controllsignals for backlight an provide an external one -> the backlight works fine
-messured the voltage on the crystal-pins -> oscillates at 14Mhz
-messured the Signal of the keys -> they are ok; high if unpressed an low if pressed
I do not know what I shoud do now. The schematics in the servicemanual I have are not complete. The part about U6 an some else are missing.
Has anyone has an idea what the problem could be?
Or has anyone the missing part of the schematic?
Hier the Voltage that i messured at some (in my opinion) intersting testpoints. I used my oscilloscope, so the absolute precesision is about 100mV. If you need an precise value of a testpoint I can messure it again with my digital multimeter (precision about 10mV).
5V Powersupply: 5.14Vdc 30mVac
3V3S1: 3.36Vdc 6mVac
VDDC_1V8: 1.83Vdc 4mVac
V33_1: 3.56Vdc 4mVac (even though its named V33 a 3.5V LDO is used; in the schematic too)
VLCD5V1: 5.01Vdc 50mVac
RST: max. 50mV (highest peak)
All the voltages are messured against GND (see picture).
Thank you for help.
I'm sorry about me bad english, its not my native language. I hope you will forgive me.
Sebastian
Thank you for help.
Sebastian
