HP ZR22W burning mode
  • androw ezzat
    • Nov 2020
    • dasd
    hallo i have HP ZR22W
    ​ have burning mode the screen flicker bule.green.whit .red
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • russianbar
    SONY KD-65XE7002 Screen Flicker
    by russianbar
    This isn't my video but it's a fair representation of the fault I have, starts with slight screen flicker as the set warms up which happens every 5 seconds or so that gets more regular until more or less constant https://www.youtube.com/watch?v=Un8cAjUtOvA was thinking T-Con but open to any other ideas as seems to be quite a common fault on these
    04-10-2025, 03:11 PM
  • DynaxSC
    Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
    by DynaxSC
    I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
    I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
    Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
    Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
    05-04-2025, 12:08 PM
