Crua CR270C shorted input.
  • redbaron1007
    • Jun 2021
    • 107
    I've got a Crua CR270C that had a short to ground on the input jack. The input was rated at 12v 4A center pin positive. When I took the board out and powered it with my bench power supply it jumped to 3v and 4A CC and a chip labeled either TM3db2 or TV3db2. I'm not able to find anything online typing in those strings of letters and numbers and searching websites like s-manuals hasn't yielded anything. It is an sot23-6 package type according to my digikey ruler and I was able to work out some of the pinout from voltages on the board and following the traces around. I'm not really sure what a suitable replacement would be for it if I cannot find the 1 to 1 replacement since I haven't had a ton of time to sift through datasheets on digikey or mouser and don't really know from looking at the board what the output should be. I'm assuming it is supposed to be outputing 5v to the rest of the board, and that the 5v would be stepped down somewhere else for the logic chip that's under the heatsink on the board.
  • lotas
    • Jan 2016
    • 4530
    • Russia
    TM3xxx - TMI3253
    The output voltage of the microcircuit (Vout) depends only on the ratio of the values ​​of resistors R2 and R3 and is determined by the formula: Vout = Vfb • (1 + R2/R3), where Vfb = 0.8 V.
    • lotas
      • Jan 2016
      • 4530
      • Russia
      What's wrong, it doesn't fit?
      • redbaron1007
        • Jun 2021
        • 107
        I had some confusion at first because the first datasheet I found was for the TMI3253SH which has a different pinout, but I managed to find one for the TMI3253/S/T and that one has the same pinout as your attached image. I think it's the right one for the job, but I won't know for certain until I get the ones I ordered from aliexpress in and can install them.
        What really sucks is I swear I have a spare board for this monitor somewhere in all my parts boards that has the part I need on it I just can't locate it.
        I do appreciate the help and I'll try to remember to report back if it's the right part or if there's any other problems when the parts come in.
        • redbaron1007
          • Jun 2021
          • 107
          I got the TMI3253 I ordered from LCSC today and popped one into the main board and it fired right up without any issues. Thanks for all the help finding the correct chip.
          I would love to know what actually killed it in the first place, but I'm just going to have to assume low quality display circuitry failing prematurely or bad luck of the draw for that part in general.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Dylan Jones
            MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
            by Dylan Jones
            I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
            I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
            06-28-2025, 05:07 PM
          • Yanleb
            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
            by Yanleb
            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
            D608, good
            D618 RF101L4S, good (See warning 1 below)
            D619 RF101L4S, good (See warning 1 below)
            D865 RF101L4S, shorted (See warning 1 below)
            IC464 Inverter HA MC74HC1G14, shorted...
            03-09-2020, 12:00 AM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
