Fix an LCD Monitor for cents
+ More Options
Posts
  • davmax
    • Dec 2005
    • 899
    LCD monitors have a low power switching regulator operating from about 360 volts DC (rectified AC power). Typically there are two resistors connected in series that take standby power from the 360 volts, this power is used to switch the LCD ON. These are high value resistors, about 470K each, resistors do not like high voltage across them, it causes them to degrade and go higher in resistance, sometimes a virtual open circuit. Their heat dissipation is well within rating at about 69mW, but they have voltage stress 24 hrs a day.
    When a LCD display has problems switching ON or refuses altogether go looking for these two high value resistors connected to the positive side of the high voltage input capacitor and replace them with THREE resistors to reduce stress eg if the original is 2 x 470K replace with 3 x 270K or 300K. Two of these resistors are straight replacements, the third is a little different. On the underside of the PCB locate the copper track that connects the two series resistors and cut it, next solder the third resistor to the two solder points either side of this circuit break.
    Fixed for a few cents worth of components.
    This failure is the result of design error where it is not realised that there is too much voltage stress on the resistors. The problem occurs in many products that use the same design. I have found this problem in VCRs.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Fix an LCD Monitor for cents
    see this often in psu's
    comes off the doubler and to a zener to get the lv supply to the smps chip.
    see a bunch open.
    • davmax
      • Dec 2005
      • 899
      Many high power PSUs today use a small transformer to deliver the quite high standby power requirement, thus avoiding the issue.
      Nvidia 8500GT 256Mb
      33 way card reader
      Windows XP Pro SP3
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        every one of even the newest/biggest pc psu i have seen still use the resistors and zener to run the chip.
        not to be confused with +5 stby
        • davmax
          • Dec 2005
          • 899
          I did not realise that thanks. I have yet to experience this.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • davmax
            • Dec 2005
            • 899
            It is a long time since I checked the voltage rating of non SMD resistors, so I thought it would be worth a re-check. The lowest voltage rating is 200Volts so two resistors of equal value in series should cope with 360 volts. So it may be that poor quality resistors are the problem of going high in resistance rather than a design problem causing undue stress. Interestingly I discovered that some SMD resistors can now stand 3000V and many can stand 500V.
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • PeteS in CA
              • Aug 2005
              • 3578
              • USA, Unsure of Planet
              I think this is usually just for initial start-up, then there is a winding on the transformer that supplies Vcc for the PWM.
              PeteS in CA
              • wil
                • Jun 2007
                Would this cause a completely dead condition, no led light, no power, no display?
