Envision LCD Capacitor Advice
  • TomInTX
    • Apr 2014
    • 7
    This relates to my son's Envision G2016WA1, LCD monitor.
    A little background, I am mechanically inclined and fix my own cars/trucks, but have not gotten deep into electrical components before.
    Last night my sons Envision monitor starting to show the common problem of turning on but going off after 2 seconds, the green power light stays on. If you turn it off and then back it will go another 2 seconds then shut off again.
    Reading the forums this looks like a common problem. I also read about a test whereby you shine a bright flash light to see if you can see the windows background. With his, you cannot see anything it is just black.
    I would really like to show my son that you can fix electronic things and not have to buy something just because it isn't working.
    I am asking for some advice with this problem.
    We have it open already, and I'm not an expert to tell if any of the caps are swollen, so I included pictures A,B, and C. Are any of these caps swollen, will replacing these fix the problem?
    Thanks in advance,
    Tom
    Re: Envision LCD Capacitor Advice
    I do not see any bulging caps, but bad cap can look normal.
    Since you do have 2-second to black, it can be the MOSFETS that drive those two black high voltage inverter transformers, bad winding on the inverter transformers, cold/bad solder joints, bad lamps. etc.
    Can we see good clear pictures of the bottom side of the board?
    • Agent24
      I see dead caps
      • Oct 2007
      • 4981
      • New Zealand
      I can't see any in those photos that are bulging - but that doesn't mean they are OK.
      They appear to be Hermei brand which are not very good, and I have personally replaced some of them in an LCD monitor that looked OK but were bad, so it's a bit higher than average chance they are the problem.
      If you have an ESR meter you can easily check them against the datasheet to see if they are in specification... but probably you don't have one and since they're low quality you might as well just replace them anyway.
      If you are unsure what to replace them with, post their details here, series, size, values etc.
      Bear in mind that replacing them may not solve the problem, and you may need to do more in-depth troubleshooting.
      -David VanHorn
      • TomInTX
        • Apr 2014
        • 7
        budm and Agent24,
        Thank you so much for the fast replies. Another thing I noticed is that when I press the power button and during the two seconds it works, there is a faint buzzing sound coming from the area where the left speaker is, I don't know if it normally makes this sound, but it goes away when the screen goes black.
        I don't have an ESR meter to check them, I will write down all their values and post them here.
        I took more detailed pictures, as requested, of all four sections of the board they are attached below.
        Tom
        • SteveNielsen
          Retired Tech
          • 2327
          Please remove the board and get some clear pictures of the bottom of the board too.
          • TomInTX
            • Apr 2014
            • 7
            Here are pictures of the backside of the board as requested. Tom
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
            • chth96
              How can I test non-polarized capacitor?
              by chth96
              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
              06-02-2024, 07:31 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • chth96
              Should I replace polymer capacitor?
              by chth96
              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
              Is this ESR value of polymer capacitor correct?...
              11-18-2022, 04:22 AM
