Neovo E-17DA flashing on and off
    Hi everyone!
    I have a Neovo E-17DA that started suffering the usual two-seconds-to-black syndrome. I installed a new inverter board because this worked a few years ago when the monitor presented identical symptoms.
    The new inverter worked for a couple of days, although on a couple of occasions when I turned the monitor on it went weird, displaying a shrunken version of the desktop background image in the middle of the screen surrounded by black. Turning the monitor off and then on again returned it to normal.
    But after two days the monitor went back to black, but now it is cycling on and off, flashing on for a split second before going to black and then flashing back on again. The green LED blinks every time it goes to black.
    I realise that it's an old monitor but I'd love to have a go at repairing it before I consign it to history. Any help would be greatly appreciated!
    Re: Neovo E-17DA flashing on and off
    I suspect bad solder joints in the power section.....
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      Hi, cheers for your reply.
      What do you mean when you say power section?! I thought the inverter and the power section were both combined on the same board?
      I have some pictures below of the old inverter (INV17) and the replacement I was sent out (GL877) which, as you can see, are similar but not identical. These pictures are not mine but taken from websites selling the boards.
      Old inverter (INV17):
      New Inverter (GL877):
