I got board from Samsung 203B, recapped, voltages fine but no backlight. Fuse was replaced, transistors are good. Transformers measure resistance OK but CT-micro says inductance of one secondary is 5,97 H, the other 6,99 H. So I guess one transformer indeed is bad after all? It's 8,13 vs. 9,9 out-of-circuit, 1335 vs. 1350 ohm.
It is TM-203B, I found that most likely the TM-1221/TM-1222 would be replacement. It has 155 uH primary no idea how much the TM-203B has, but core has same size, it looks 100 % same (same color of plastics and so) and both have 1350ohm secondary. Only found it at Ali Express for 10,8 bucks a piece in a bulk of 5
