Samsung Odyssey G9 (c49g95tssr) no picture or backlight. Power LED shows
  • grimreaper420
    • Sep 2024
    • 41
    Originally posted by lotas
    Does this transistor have all legs 1, 2, 3 shorted?
    I'll check now
    • grimreaper420
      • Sep 2024
      • 41
      yes! i checked the 2 circle highlight in diode mode in multimeter and it beeps and shows 0.000 on all 4 no matter which way i test in whichever combination
      • lotas
        • Jan 2016
        • 4708
        • Russia
        #63
        Originally posted by grimreaper420
        I'll check now
        You circle the entire transistor, and not one of the terminals, so you think what comes to all the terminals.
        • lotas
          • Jan 2016
          • 4708
          • Russia
          #64
          Don't you see that I circled 2 under the number (this is one conclusion, they are connected together by paths), and 1 and 3 are different conclusions!
          • grimreaper420
            • Sep 2024
            • 41
            ah i see. black probe on 3 and red probe on 2 returns 0.476v (in diode mode), otherwise everything else returns OL
            • lotas
              • Jan 2016
              • 4708
              • Russia
              #66
              It's working, but it's hard to check remotely with you, I'm already tired, check these points again, between 1 and 2, between 1 and 3 and between 2 and 3, what's the resistance.
              And also with 4 (1-4, 3-4).
              • grimreaper420
                • Sep 2024
                • 41
                in diode mode it all comes out at OL, apart from 3-4 it is 0.417v
                in Ohms it just from 12 all the way down to OL back up to 12 and keeps doing it.
                its been a long few days. we can take a break for a few days and come back to it
                • harp
                  • Jun 2022
                  • 616
                  • Planet Earth
                  #68
                  Yes and before break, please fill next table, so we can thinking awhile... about mistery DFN component...
                  Set multimeter in diode mode, and firmly put red (yes RED) probe to ground (marked arrow GND on image)
                  Then with black probe firmly touch solder blob arround chip, marked with number and write down measurement reading. Do few times, reading must be the same.
                  1 - ?
                  2 - ?
                  3 - ?
                  4 -
                  5 -
                  6 -
                  7 -
                  8 -
                  9 -
                  10 -
                  And also for fuse and mosfet
                  X -
                  Z -
                  W -
                  Y -
                  • grimreaper420
                    • Sep 2024
                    • 41
                    Then with black probe firmly touch solder blob around chip, marked with number and write down measurement reading. Do few times, reading must be the same.
                    1 - ?
                    2 - ?
                    3 - ?
                    4 -
                    5 -
                    6 -
                    7 -
                    8 -
                    9 -
                    10 -
                    X -
                    Z -
                    W -
                    Y -
                    Here are my results (red probe on GND on the image)
                    1 - 0.402
                    2 - 0.530 / 0.533 / 0.531
                    3 - OL
                    4 - 0.559
                    5 - OL
                    6 - 0.001
                    7 - 0.009 / 0.011 / 0.012
                    8 - 0.560 / 0.559 / 0.561
                    9 - 0.517 / 0.515
                    X - OL
                    Z - 0.020
                    Thank you for the help Harp & lotas
                    • harp
                      • Jun 2022
                      • 616
                      • Planet Earth
                      #70
                      10 -
                      W -
                      Y -
                      So, I guess that on point P in picture is ground, confirm?
                      Before future, can you tell us what you can do and what tools you have, I ask because I am not so confident regardless to your data input, but see strong will
                      Experianced in desoldering smd -
                      Experianced in ripps pads -
                      Know basic process of microsoldering -
                      Lab PSU -no
                      Some 5v adapter for phone with round connector (what mA?) -
                      Any chinese module for control voltage, current -
                      Thermal camera -no
                      NTC sensor (from laptop battery) -
                      Thermocoupling wires for DMM -
                      Solder iron (controll temperature,?? Watt, what tips) -
                      Soldering tin -
                      Soldering wick -
                      Soldering flux -
                      IPA -
                      Hot air -
                      Fine tweezers -
                      DMM -yes
                      Handheld magnify glass about 10x, or maybe on phone -
                      Anything else -
                      • grimreaper420
                        • Sep 2024
                        • 41
                        10 -
                        W -
                        Y -
                        Lab PSU -no
                        Thermal camera -no
                        Soldering tin -
                        Soldering wick -
                        Soldering flux -
                        IPA -
                        Hot air -
                        Fine tweezers -
                        DMM -yes
                        Anything else -
                        for point P i connected red probe to ground part and black probe to point P in diode mode returned 0.000 / 0.0001
                        10 - 0.514
                        y - 0.469
                        w - 0.469
                        im not experienced with electricals (but i am learning). I only have DMM. I can buy any extra equipment needed though​
                        • harp
                          • Jun 2022
                          • 616
                          • Planet Earth
                          #72
                          Oh, so... you realise that only with dmm you can not do much... I explain to you on ic 5228E example
                          1 - 0.402
                          3 - OL
                          4 - 0.559
                          5 - OL
                          6 - 0.001
                          9 - 0.517 / 0.515​
                          10 - 0.514
                          About that ic we known almost nothing... the measurement on all pins you want to see like 'identifier', so you see that pin 4 and 8, and pin 9 and 10 may be connected together or have same properties eg inputs. Pin 3 is probably provide power, based on thicker track and near smoothing capacitor.
                          Also, you see there is very suspicious reading on pin 7, and pin 5.
                          Pin 7 connect capacitor parallel with ic, and for some reason it is suspicious low reading. Next step would be to desolder that cap (with iron, you dont want stres ic for that trivial job), measure it off-circuit, and repeat measurement of pin 7 without it, while we hope that low redings are not come from ic or that it consider normal... That involve tools and practice (experiance), first you can buy, second dont.
                          Pin 5 must read more likely like pin 7, if your resistor is ok (10 ohm) and you previous confirm that it have 10 ohm accross it. So, the provided data is not match, and you must see why. That observation and that conclusion you have first noticed while measuring, so bring attention.
                          With dmm you can do in-circuit measurement, basicaly resistance and voltage. While resistance is done wth disconnected monitor from mains, the only risc is mechanical damage with probe tip, or wrong measurements. If you measure voltage, the risc is very very high, because your probe may slipped a little bit and short somethin, and it is game over, you cant buy replacement 5228 ic for example. So that you lower the risc, you must practice, know that you do not measure directly on legs of that small chip but on exposed near components, or gently scraped on wide part of track...
                          If you take my sugestion, that is nice expensive monitor, and you must first know and impruve your abilityes to work with needed tools, so, put it aside a bit, and practice some time on cheap stuff like power supply, old laptop and so on...
                          When you do couple smps repair, maybe you have to ask yourself, is that your monitor adapters is ok, have it provide declared power under load, because it is first common on both monitor...
                          • grimreaper420
                            • Sep 2024
                            • 41
                            1 - 0.402
                            3 - OL
                            4 - 0.559
                            5 - OL
                            6 - 0.001
                            9 - 0.517 / 0.515​
                            10 - 0.514
                            Ah okay. I will practice on some other small repairs and soldering first.
                            I bought a Lab power supply and thermal camera today. So that might help with diagnosing too?
                            • grimreaper420
                              • Sep 2024
                              • 41
                              Just used the thermal camera, and can't see anything suspicious. I imagine, the other side of the board is not heating up because the fuse it blown, but weirdly the power button still works, so I'm not sure how its getting power if the fuse is blown.
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • gl4709
                                Samsung un55cu7000d with backlight and sound No Video / Picture
                                by gl4709
                                I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                01-23-2025, 06:21 PM
                                09-07-2024, 05:50 AM
