Dell E173FPf partly resurrected
  • jarsudsco
    • Mar 2014
    • 28
    I'm a newbie here and a trying to get back into repairing things rather than binning them. So please bear with my first attempt at posting...
    This is a board from a Dell E173FPf 17" monitor. I've not been able to find a service manual or schematic online.
    It's original fault was simply completely dead. There were no obvious burned-out components or bulging caps so I decided to try the heavier silicon stuff! I removed Q850 marked '27611' a MOSFET I believe ('A' in my component side image) and D854 marked 'SRF10-10' - a Schottky Barrier Rectifier (B).
    With a DMM the MOSFET seemed to be ok (I need to find a more thorough guide to testing MOSFET's), but the Schottky diode pair read O/C across both legs. In my "spares" collection I found another Schottky diode pair - an S16C40C, somewhat under-specced compared to the original but I thought I would try it just to see if I got anywhere. I resoldered the MOSFET and my alternative Schottky diodes.
    Much to my surprise, the power LED on the monitor now flashed green/yellow - apparently classic Dell for PSU problem - but at least there was *some* power now. (I also discovered the original SRF10-10 seems to have a pretty poor reputation, so I'll look for a more compatible alternative.)
    So, the situation now:
    Voltage across C854 (F), main capacitor hot side - 333V stable (UK mains, so 240V in)
    Voltage across C862, C864 and C869 (C, D and E), what I take to be the main output caps - all around 4V - unstable, varying by +/- 1-2V
    I dug out my old scope and luckily it still worked. Wasn't sure where to start so tried across the secondary (or could be two secondaries in parallel?) of the main transformer T850 (G).
    The scope showed regular short bursts of voltage, maybe 2-3 bursts per second, each burst a short decaying roughly sinusoidal voltage. I have a very short avi of the trace, if I can't post that here, I'll try and get a still of the relevant frame.
    I'm wondering if it might just be my poorly matched Schottky diodes but my instinct says look elsewhere, I'm just not sure where next.
    Fascinating though this new-fangled stuff is, linear PSU's where a helluva-lot easier to troubleshoot! But my aim is to learn...
    Any suggestions would be most welcome.
    - jarsudsco
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell E173FPf partly resurrected
    Q850 is...AP2761I-A,N CH,650v,10A..mosfet testing this may help !!
    http://www.4qdtec.com/mostest.html
    Most problems I have had with these,are usually caused by U850 itself,and its associated components.D854 can also go short cct,Perhaps the first step maybe to change the start up cap for U850 C857
    • jarsudsco
      • Mar 2014
      • 28
      @Rtech - thank you for your reply.
      The mosfet testing guide you referred to had basically the same info in it I'd found previously but it was good to have it reinforced so thanks for the link.
      Q850 passed the test from the link you suggested so it went back on the board. I replaced C857 although the original did register a value of close enough to it's stated value of 10uF not to worry about it, so I suspect it was ok.
      I double checked for bad/dry joints and even retouched the solder on U850 just in case.
      The voltages and scope-traces remained the same so I'm thinking it might be U850 itself as you also suggested. I've ordered a replacement and it will probably take a while to get to me so in the meantime any other suggestions as to how to proceed would be welcome - any alternative suggestions for the SRF10-10 would be good too.
      Many thanks again,
      - jarsudsco
      • Rtech
        • Jul 2010
        • 1095
        You are ptobably correct in replacing the U850,hopefully it is just that which has failed,As Far as the Schottky goes.Any designated one woild probably do, that is 10Amps 100v min.
        I have some new MBR10100CT ones, more than i will use, and would happily stick one in an envelope for you, if you PM me your address, no charge.I am from South Shields originally.
        • jarsudsco
          • Mar 2014
          • 28
          @Rtech
          Wow, that's very kind of you to offer.
          A sand-dancer eh... I'm from just down the road in Jarrow.
          I'll pm you - that'll save me scouring data sheets this afternoon
          • jarsudsco
            • Mar 2014
            • 28
            Just an update to say success! The replacement PWM controller chip arrived in today's post and after some very fiddly de-soldering and resoldering the monitor is up an running again.
            @Rtech - You were spot on. Thank you again for the advice and the Schottky diodes.
            Inspired by today's result, I'm now waiting eagerly for some other replacement components to arrive.
            - jarsudsco
            • Rtech
              • Jul 2010
              • 1095
              It does feel good, when a plan comes together >>
              • iyas132
                Corsair RM 750 blown schottky diode near ES1DF
                by iyas132
                Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                Can anyone help me identify the component...
                12-30-2024, 01:34 AM
              • Crystaleyes
                iMac screen problem - PSU schottky's failing?
                by Crystaleyes
                have another iMac with flickering then black screen issue.
                It is a 21.5" 2010 A1311 model.
                When switched on, the screen flickers before going black. With a torch you can see the image is there, as are all four diagnostic LED's.
                Measuring the PSU output only gives around 10.5v with the cable harness connected, although it measures 12.06v unconnected. This leads me to suspect something the power supply.
                I saw that some people had found a shorted mosfet on the output however these seem fine, when tested for...
                03-31-2022, 06:55 AM
              • Fuzer
                Dell e173FPf board schematic
                by Fuzer
                I there
                I have an old Dell e173FPf lcd monitor that when i press the power button doesnt give any signal, no power light anything.
                Can anyone provide me the schematic for this board for me to try to troubleshoot the problem?
                Best regards
                Fuzer
                11-12-2022, 08:12 AM
              • notallbad
                Samsung UE37D5520 boot loop partly fixed
                by notallbad
                So the tv is a Samsung Ue37D5520, found a UE40D5520 tv with what I believe to have a faulty panel so out comes the main board to donor into the 37".
                Board connected and tv powers on and appears to stay on but what should I do before doing any reset, fw update, connect to a network or use apps etc...???
                Also should the usb update file be for the UE37 or UE40???
                thanks
                08-01-2022, 03:42 PM
              • Lien1454
                Belkin F5D4076-S v2 Powerline Adapter. Bad Cap and SCHOTTKY RECTIFIER
                by Lien1454
                Firstly I'm quite the amature at fault finding.
                I have a pair of Belkin F5D4076-S v2 powerline adapters. One is working the other is dead.
                On opening the dead one. I spotted a bulging cap which is a 6.3v 2200uF.
                Measuring it with a MM reads 1900 uF.
                There is also next to it a SM SCHOTTKY 399F SM340C. On testing this for continuity there is none. However on testing the other powerline there is continuity. So looks like I need to replace that also.
                I cannot find any Schematics for the powerline. I've been able...
                12-12-2020, 05:03 AM
