Hanns G HG281D showing menu on its own
  • designer
    • Mar 2014
    • England
    Hi guys, great forum. I have searched through it and found lots about the Hanns G HG281D. However I have a slightly different problem with it that is gradually getting worse. It started off with the brightness menu and main menu showing on it's own sometimes, and when you click off it, it come back straight away. Today the brightness menu decided to appear on its own and stay on. If I turn it off and on, it does the same thing.
    I don't know if it is related but the other day the monitor decided to switch itself on and off every so often. Is this all down to a bad cap? If so which should I replace? Thanks so much for your help guys.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Hanns G HG281D showing menu on its own
    I'd say leaky push buttons most likely.
    Due to moisture oxide builds up inside the buttons, and that creates resistance, so instead of an open circuit the button is now a resistor when not pushed in. Over time, this resistance gets lower, and the control board thinks the buttons have been pushed when they have not.
    Replacing all the push buttons should solve your issue. They can be taken apart and cleaned, but then the problem comes back after a few months.
    A working TV? How boring!
    • designer
      • Mar 2014
      • England
      Awesome thanks so much. Is there a specific type of push button I should replace it with? (sorry about the noob questions).
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Anything as long as it physically fits.
        • designer
          • Mar 2014
          • England
          Great thanks.
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
          • Ierwin
            Philips 58PUS7805 Menu working but no/weird picture from video sources
            by Ierwin
            I got a 58pus7805 that shows some weird behavior.
            The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
            However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
            I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
            I managed to install the latest official firmware by holding the control button while plugging...
            03-10-2024, 12:50 PM
