PS4 pro power supply coil whine
  • satouri abdellwahed
    Abdelwahed
    • Mar 2024
    • Tunisia
    I have a PlayStation Pro that has a buzzing and ticking sound from the back on the side of the power supply. I searched for a solutions , i tried to make reflow for some of the components but it did not work. In addition, I used silicone on parts on board without any changement. I discovered that if I make a short on the IC in the left corner, the noise stops. Is that dangerous?
Name:	Capture d’écran 2024-03-26 192805.png
  • Samsir
    • May 2020
    • 15
    • Bosnia
    I have repaired numerous PSU's and I have seen this problem several times.
    The problem is not any of the components you have tried to reflow. Problem is that this is a Chicony PSU. I have yet to see this problem from a Delta PSU.
    The smd capacitors used on these boards, specifically for the PS4 Pro seems to have a spec problem. The problem is that the PSU might work, but it turns off under load above 4-5 Amps. Or it might not turn off, but make a "coil wine".
    99% of these cases are out of spec SMD capacitor(s), or physically cracked parts. Problem is they still might "work" and check out OK during prodding, aka. Not being short. But as soon as there is any load the sounds start. Sometimes it might take a few minutes before it starts, sometimes not.
    The sound normally comes from the main filter cap, just after the Bridge Rectifier. This Cap is though very unlikely the problem.
    The shorting of the chip you are referring to is NOT a cure, but might mask the problem for a little bit when PSU is without load. Using Silicone is the same thing. It might mask the problem, but is no cure.
    The normal disclaimer!! PSU's might KILL you if you do not handle them properly and you start prodding around. Remember the main cap holds up to 400V.
    ALWAYS completely discharge the main Capacitor, eighter with a special drainage tool or resistor before you work on them. If you are unfamiliar with this procedure, do NOT work on them.
    I do not know your experience with PSU's, but I would suggest sending it to a professional. If you are a professional, I might guide you in the right direction..
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • Gjackson
      ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
      by Gjackson
      Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
      01-13-2024, 10:34 AM
      07-01-2024, 06:34 AM
    • 90Ninety
      Coil Whine , buzzing, identifying parts R9 Fury
      by 90Ninety
      I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
      I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
      Perhaps likely is that I am missing something else it could be , here is a stock picture...
      12-15-2022, 04:18 AM
