Sony fw-55bz35f professional display
  • EazyBone
    • Jun 2023
    • 1321
    • United states
    This Pro TV has no power. No light indicator or nothing.
    I checked standby and all other voltages, it has zero volts on every point of connector.
    Fuse is fine
    Main cap gets 160v steady
    I can't find any voltage on the cold side, the hot side does have some things.
    Is it possible something has gone bad but didn't blow the fuse? Any direction would help. I'm pretty damn sure I should at least get standby... But these sonys mess with my mind.
    • 12145
    • U.S.
    Start with basics, I check the diodes, resistors and transistors on top of board first, then check the bottom and check for bad solder joints, if nothing found can go from there.
    • EazyBone
      • Jun 2023
      • 1321
      • United states
      Yes, I'm feeling the need for some reassurance lol, I don't get any voltage coming off the octocouplers, I guess I'm looking for reassurance that it's not mysteriously the main board not turning on the stupid power board because sonys just suck imo lol
      But all resistors seem fine, too late to check solder joints but will be a tomorrow thing.
      I get your name now, damn sonys
      • R_J
        • 9535
        The first voltage you need is standby voltage, check fuse resistor R915, ic901 is the standby pwm. If the resistor is open ic901 is likely bad.
        You need 3.3vdc across C950a (or check for 3.3vdc on FB950 (near cn6401)
          • 12145
          • U.S.
          My xbr65x900c was a nightmare, spent WAY too much time messing with it, was just trying to figure out the issue. Funny thing is, this 900c is edge-lit so the picture is always going to be substandard compared to full array, it's not worth shit imo.
          • EazyBone
            • Jun 2023
            • 1321
            • United states
            So I already ordered replacement PSU because obviously it's the PSU, and yes the original was dead
            R915 is fine, is there a way to test ic901 in any way?
            Always curious to try and fix a psu
            • R_J
              • 9535
              Check the voltage on the ic's drain pin (lpin 5) looks like pin 8 is hot ground. If you have that (160vdc) voltage, check the ic's vcc voltage, using hot ground for meter negative, check the voltage on pin7 or D902 cathode (white line) and D902B, these voltages should be around 20vdc depending on the state of the ic.
              If you have around 9vdc or the voltage is changing between 9~15v on either of the two diodes it may be that C904b or C907 is bad, don't check them just replace them.
              • EazyBone
                • Jun 2023
                • 1321
                • United states
                Great thanks, will check this out within the week or so and post results. Got a backlog of tvs to handle :/
                Thanks!
                • droxide87
                  • Nov 2024
                  • Trinidad & Tobago
                  Hello, I know it's a little off-topic, but I'm trying to source the firmware for this exact model, but it seems sony has discontinued support and google is a big let-down, any chance someone can direct me to a source? would be greatly appreciated!
                  • Carlos#2003%
                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                    by Carlos#2003%
                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                    02-15-2024, 07:52 PM
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 05:27 AM
                    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                    09-06-2024, 05:30 AM
                    Sony VAIO SVE1413XPN Notebook E Specification for Upgrade or Repair
                    This specification for the Sony VAIO SVE1413XPN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVE1413XPN boardview and SVE1413XPN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
