Samsung 2493HM/BN4400195A: let's cut it finally!
  • Behemot
    • 4845
    • CZ
    All those other threads got so messy I decided to start a new one and try to go through all possibilities to bring it back to the alive ones. I still got that first one, unable to repair it with possibly bad main transformer or resonant transformer So if not both, at least making one out of two would be possible solution.
    So I got second one, with that yellow bloat carbonated almost at each spot, both transistors, 0R22 resistor and one fuse blown. At least it was easy to get rid of that glue. Cleaned it everywhere, I've replaced transistors, resistor and fuse.
    When I plug it in just as it is, I get +5 V SB OK. With inverter connected and running on light bulb, I get no image but the bulb blinking and some noises like if something was in short from inside the display.
    I found no bad semiconductors - at least not shorted, still there is possibility of some of those bloody zeners not working. I do have 2kV O-scope probe this time so I can proceed with measuring the main transformer primary, but is there anything else to check first? I also do have Karl-Heinz Kübbeler's universal tester as CT-Micro v1.0 from Mikhail so I can do more proper testing of components this time!
    • replaced main transistors
    • replaced RM801 0R22
    • replaced fuse
    • cleaned all that stuff
    • checked semiconductors with diode tester
    • checked CM812 fine (15,6 nF)
    • checked RB801S (44R) - measures 33 ohms in curcuit
    • checked RB808 (2R) OK
    • checked RB802 and the other one (100k), OK
    • checked caps, they are good to replace but nothing drastically out of spec on first sight
    • main stransformer primary measures 74 mH
    • measured CM809 65 pF
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung 2493HM/BN4400195A: let's cut it finally!
    If there is an arcing/ shorting noise from the display then make up another test bulb
    and try and eliminate the noise. Have you tried the test bulb you have in place of each bulb?
    Now wondering if you have a test bulb in place of one ccfl or you mean your using the dim bulb test on the mains input.
    • Behemot
      • 4845
      • CZ
      I have the bulb in series with the power supply board, to protect it from burning if there is any problem on the hot side.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Yes that what I wondered.
        How about plugging the bulbs from set one into the inverter to see if they light and noise stops?
        • Behemot
          • 4845
          • CZ
          What is set one? All six lamps were connected to inverter.
          • Behemot
            • 4845
            • CZ
            CM809 measures 100 pF out of circuit, should be 47, will replace and try.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              So I was suggesting plug its back lights , or one of them into this second set/monitor/ machine
              • Behemot
                • 4845
                • CZ
                I see. Well that PSU was not working either so I don't really see how that could help. Both had blown transistors and that 0R22 resistor, don't think there is anny difference in the selection, just maybe the second was easier to clean of the glue so it may be done better.
                • repair-it
                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                  by repair-it
                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                  10-11-2023, 07:18 PM
                • ezenia
                  LUMIMAN Smart Bulb IC ID?
                  by ezenia
                  I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                  In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                  04-28-2025, 05:56 PM
                • Larrob19
                  Samsung TV UN75NU7100/Power Board BN44-00874C
                  by Larrob19
                  I have a Samsung power board BN 44–00 874C that is dead. I have looked for a schematic but no such luck. I opened it up and found two Mosfets burnt QP801CS and QP802CS, also the main fuse. I replaced them and checked the two blue capacitors in front of them. They both tested good. I checked the Diode on the same heat sink and the two capacitors in front and they checked out OK. I plugged it in again and that blew the fuse and the Mosfets the second time. I plugging it in again hooked to a 100 W watt light bulb. The light bulb starting started flashing off and on. I checked...
                  05-08-2025, 12:49 PM
                • Loretto
                  Samsung SMPS BN44-00339A
                  by Loretto
                  this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                  I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                  I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                  I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                  03-29-2025, 08:30 AM
                • Loretto
                  by Loretto
                  03-28-2025, 10:28 AM
