Monitor was a Dell E151FP. Symptom is 2 seconds to black. The transformers seems to measure fine. Found two blown transistors at the inverter section. Now the problem is that its kinda hard to find 2SD1802 especially in TO-251 package (found mostly TO-252 ones). Thus the question is, can I safely replace them with another/alternative transistor such as...
- 2SC5707 (TO-251, closer to original specifications but higher current)
- MJE3055T (TO-220, lower frequency)
Are there any other transistors besides the ones I've listed above, that can be considered/recommended?
Also do I have to replace the other two 2SD1802 transistors on the other side with the those alternative replacements also (as to match both sides)?
