Samsung S19A100N ghosting picture..
  • T-con
    • Dec 2013
    • 57
    • Taiwan
    What do you think is the problem with this lcd monitor? You can see ghostly image at the background Any help will be appreciated .
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: Samsung S19A100N ghosting picture..
    Disconnect the LVDS cable to the Tcon board (wrap a plastic cover/bag around the connector to prevent accidental shorts between the exposed panel metallic casing with exposed contacts on the connector). Plug the monitor to a PC, and just pause it on the BIOS setup screen (keep tapping the BIOS setup key when power on, no need to boot all the way to Windows or any other operating system). This should present a white screen. Does the "ghost image" still appear on this white screen?
    • T-con
      • Dec 2013
      • 57
      • Taiwan
      Thanks for replying, the ghost image in the attached pics is when theres no connected cpu, i can see the no connected input box moving around the screen but blurry, is it a bad panel?
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Hi,Thanks for replying, the ghost image in the attached pics is when theres no connected cpu, i can see the no connected input box moving around the screen but blurry, is it a bad panel?
        Bad panel is a possibility. First, try cleaning the LVDS connectors. Then check the voltage to the Tcon board (to see whether there is a problem with the 3.3V regulator or MOSFET that controls power to the Tcon board). I would recommend changing all capacitors in the power adapter (to rule out ripples going to the panel). Also replace any electrolytic capacitors on the main board. Do use good and recommended capacitors such as Panasonic FM, Panasonic FR, Nichicon HE, Nichicon PW, Panasonic FK, Panasonic FC, Nichicon PS, Nippon Chemicon KZE, Rubycon ZLJ, Rubycon ZLH, etc...
        • T-con
          • Dec 2013
          • 57
          • Taiwan
          Ok i'll try it before looking for a replacement panel, thanks.
            Looks like the VOFFE or VONE voltage is missing, any part# for LCD panel (on sticker marked e.g. SAMSUNG LTI19A####, AU OPTRONICS LXA19######, etc.)
            • T-con
              • Dec 2013
              • 57
              • Taiwan
              I'll check tomorrow, the unit is at the shop, will post clearer pics.
              • T-con
                • Dec 2013
                • 57
                • Taiwan
                I don't see a voffe or vone, here are some pics to look at.
                • daveyjone2014
                  • Apr 2014
                  • Pilipinas
                  can u help me this is my same problem what should i do?
                  • T-con
                    • Dec 2013
                    • 57
                    • Taiwan
                    The panel is the fault, the only fix is to replace the whole lcd, and finding a replacement is difficult, so i've given up on this monitor and bought a new one.
                      09-07-2024, 05:50 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • Mgiffune
                      by Mgiffune
                      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                      I ordered a supposedly β€˜new' Tcon board this time, and
                      06-09-2024, 10:28 AM
                    • shlomim412
                      samsung ua55es6800 - no image
                      by shlomim412
                      hi
                      having problem with samsung ua55es6800
                      tv had backlight on, sound working - responds to the remote control but no image.
                      check tcon board - had 12v in but no other voltages present.
                      when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                      when leaving only left side connected - again no voltages and no image.
                      put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                      kept trying to block less pins on the left ribbon cable...
                      05-15-2024, 05:00 AM
