Acer AL1914 vertical lines on left half of screen
  • rprior04938
    • Sep 2013
    • 4
    I have a 10-year-old Acer AL1914 LCD monitor which suddenly started showing vertical lines over the left half of the screen. (See pic.) I have already recapped the power supply board. I also removed all of the electrolytic caps and diodes from the main board and checked them for capacitance and ESR. All seem OK.
    Is this monitor beyond repair? Does anyone have a main board they'd like to sell?
    Thanks.
    Rod
  • Rtech
    • Jul 2010
    • 1095
    Re: Acer AL1914 vertical lines on left half of screen
    I would probably look for a replacement Screen as opposed to the main board !!
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • Stanley1843
      by Stanley1843
      06-29-2024, 11:54 AM
    • rfxcasey
      Vertical Lines on Half of LCD Display
      by rfxcasey
      I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
      05-16-2024, 06:52 AM
    • ItalianSat
      LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
      by ItalianSat
      Hello Everybody,
      I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
      Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
      Moreover, I detached the T-CON board for a new round of investigation. I personally...
      06-28-2022, 06:02 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
