Congrats on getting the PSU running.
I would first check if the flyback transformer is operating. You said the HOT checked fine. Then see if you get any voltage outputs from the flyback. There will be a number of low voltage rails generated by the flyback, you can check those. Look for traces under the FBT leading to diodes, and measure voltage after those diodes.
PS. CTX was a good CRT monitor brand. Rebadged means renamed. CTX made it for a customer, hence the different branding.
