I have an older Samsung monitor with some bad capxon caps. I need 3 470uf, 25v and 2 1000uf 10 caps. What would be a better brand name and a good place to get them? I see I can order NTE from the Radio Shack? Thanks! Tom
Junk Capxon caps
Re: Junk Capxon caps
Unfortunately, those caps from Radio Shack will not work. You need low ESR capacitors since it's a power supply. AND, since CapXon makes horrible quality caps, you will want to replace ALL of them, otherwise you may be doing this again in the future. Usually you can leave the big single (400 or 450V cap) alone, and replace the rest. So list all of the values you have so we can post some proper replacements for you. I have seen even the smallest CapXon caps fail. And they fail faster since monitors usually run pretty hot.
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by shelby5041hi
ive got a modern digital clock radio approx 15yrs old
my question is how long can a clock radio or a simple radio last ss farcas operating hours?
since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
it uses very little power just a few watts i would imagine that may have something... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
- Loading...
