Fujitsu SCENICVIEW P15-1A power board repair
  • sermulis
    • Jul 2013
    • 38
    • Latvia
    Fujitsu SCENICVIEW P15-1A monitor was not showing any led activity.
    After opening it - one cap was bulked C922, which was replaced. After than i Was able to switch monitor on two times between not able to switch it on about 20 times.
    Checking the power board i came to conclusion, that i'm not receiving power in secondary circuit - (caps C922-C925 0V DC).
    I am receiving variable DC readings on C906 and IC901 (1 to 7 pin) from 11 to 15 Volts. Also, I am hearing ticking component in primary circuit (guessing that IC901 is not able to start)
    What you suggest me to check? Should the voltages be so unstable?
    Thanks in advance
  • Rtech
    • Jul 2010
    • 1095
    Re: Fujitsu SCENICVIEW P15-1A power board repair
    Have you checked the two SChottky diodes on the Heatsink ?? Also the most common problem on these are the 4 transistors Q 209, Q210 etc.these are common faults and used on many Boards,usually at least one pair go short cct.
    • sermulis
      • Jul 2013
      • 38
      • Latvia
      hi,
      what readings should I get for good diodes? should I test them out of circuit?
      transistors can be checked in circuit for shorts in source to drain pins?
      thanks!
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        No voltage on secondary means the PSU doesn't start. Replace the startup cap of the PWM controller, it's the one next to it. C906 in your photo. There can't be anything shorted since the monitor does power up sometimes.
        A working TV? How boring!
        • sermulis
          • Jul 2013
          • 38
          • Latvia
          hmm. but why than I am receiving variable voltage on C906? I will replace this cap and post here results
          • japlytic
            • Oct 2005
            • 2086
            I see this power supply has Hermei capacitors - a known bad brand.
            • sermulis
              • Jul 2013
              • 38
              • Latvia
              after replacing C906 monitor came back to life
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Congrats. Want me to explain the whole "startup-cap-bad" effect? I'm drunk enough to do so, but i feel like tomorrow i'll be wide awake and unwilling to, so it's your choice.
                Ok here goes. The power supply controller (most likely a UC384x variant) has two sources of power. One is a resistor from the primary HV side to its VCC pin, which supplies just enough current for it to start oscillating. The second is an auxiliary winding on the SMPS transformer, which sustains a 15-30v level for the controller to operate on, once the power supply started working and the monitor is ON.
                There are two things that can trigger erratic operation. One is a legitimate short on the secondary, on which the supply will enter what's called "hiccup mode". Which is what you've been seeing on C906. If there really was a short, replacing that capacitor would have yielded the same behavior. That means you have to check the secondary diodes, on which you most likely you would have found a short.
                The second is that the startup cap itself goes bad. This is manifested by the supply trying to start, then dropping out of regulation because the startup capacitor is dry and unable to supply enough power to the PWM chip for it to keep running, so when it starts drawing current to keep the thing running, it falls back flat on its face. This is what you have been experiencing here, and it's a common issue with primary side controllers.
                Long story short: Any time you see a PSU with a primary side controller ticking, replace the startup (Vcc) cap first. If that does not fix the issue, THEN look for short circuits in the secondary. Have fun and enjoy your stay on Badcaps.net ! Th3_uN1Qu3 out.
                Last edited by Th3_uN1Qu3; 09-15-2013, 05:53 PM. Reason: Added extra info, drunk guy mode.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                  Fujitsu CELSIUS H760 Mobile workstation H Specification for Upgrade or Repair
                  This specification for the Fujitsu CELSIUS H760 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the H760 boardview and H760 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu...
                  09-06-2024, 05:30 AM
