BenQ FP731, SMD transistor in AD board
  • TOMARRO
    • Jan 2007
    • 10
    SMD transistor marked (Q7) in "AD board" of my LCD BenQ FP731, is totally burned and I can't see nothing in its surface, my question is if someone can tell me the number of this transistor or an substitute.
    Somewhere I've read it's the same on Dell E172FPB.
    Thanks.
  • TOMARRO
    • Jan 2007
    • 10
    Re: BenQ FP731, SMD transistor in AD board
    here again.........
    The transistor I'm talking is the same in a Dell E172FPB , but in diferent place.
    I show you below:
    BenQ Fp731 (48.L8301.AA0)-----> Q7
    Dell E172FPB (48.L9201.A11)----> Q2 <--- I've saw it in a pic of this board, but his resolution don't allow read the number.
    I hope someone help me now and tell the reference of that SMD transistor .
    Thanks.
    • samykenza
      • Feb 2007
      • 7
      I gave Dell E172FPB (BENQ 48.L0J01.A00) but I don't know if they have the same "AD board" !!
      for my "AD board" the Q2==> t06
      • TOMARRO
        • Jan 2007
        • 10
        Hi, samykenza
        many thanks for your reply, but in your board, I don't know how is marked this transistor.
        I can see the legs in my "PCB" marked ( D , G , S ) -Drain -Gate -Source, "is the same", and it's near LCD panel conector , in fact, provides power to it.
        I've seen " t06 " datasheet and it's a PNP transistor (B, E, C). In my case is a
        MOSFET, but...........which?
        visit--> http://www.tkb-4u.com/code/smdcode/smdcodeT.php
        TOMARRO
        • samykenza
          • Feb 2007
          • 7
          Hi TOMARRO,
          this is a pic of my "AD board"
          near the LCD panel conector I can't find a mosfet!!! but only a transistor (B,E,C) as you can see in this pic ( the number 1 )
          I found probably a mosfat marked as Q7 !! (the number 2)
          and in this pic you can see another one but I'm not sure that is a mosfet (the number 3)
          I would to tell you also that the Q7 is the only one that is marked (D,G ,S) all the reste are marked like a transistor (B,E,C). I hope that this information can help you.
          • samykenza
            • Feb 2007
            • 7
            and sorry for my bad english :p
            • TOMARRO
              • Jan 2007
              • 10
              Hi, again samykenza.
              Don't worry for your english, I understand perfectly!
              At least what I was wayting!
              It's "Q7" , I was searching and found the complete name --> (XP151A01C3MR)
              n-channel power mosfet, that was my doubt (n-channel or p-channel) now I'm
              sure, and I can replace it.
              I'll try to find the same transistor or an equivalent, in my local shop and afterwards I'll post the result.
              Very helpfull your pics! .........many many thanks.
              greetings......from Europe .....TOMARRO.
              • samykenza
                • Feb 2007
                • 7
                Not at all TOMARRO
                please get a look here and tell me if you can help me!!? thanks
                https://www.badcaps.net/forum/showthread.php?t=3336
                • TOMARRO
                  • Jan 2007
                  • 10
                  <<GOOD NEWS>>
                  I've got, "not the original", an equivalent transistor, in my local shop (2 days wayting for it) ----> SSM3K01F by TOSHIBA, and now my monitor is working fine again.
                  Was a very difficult and delicate job! but in this moment THE PROBLEM IS SOLVED.
                  So many thanks, Samykenza for all your help...
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    good work guys
                    • samykenza
                      • Feb 2007
                      • 7
                      Not at all TOMARRO!! I'm happy for u
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • Noodneek
                        Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                        by Noodneek
                        My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                        I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                        08-30-2024, 12:52 PM
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
