Dell 3008WFP Monitor Power Shut Off & Stained Boards
  • steny
    • Aug 2013
    • 14
    Hello All,
    Beloved 5-year-old Dell 3008WFP shut off last Saturday. After about half hour of use, the monitor made a small 'blup' noise and shut off (blue power light went off and did not come back on). It was the same 'blup' noise it makes when powering on, so first thought was that it had a power problem.
    After trying different power cords and electric outlets, and letting it sit and think about it overnight - without success - Googling found the very informative threads on this forum and at Overclockers:
    https://www.badcaps.net/forum/showth...highlight=3008
    http://forums.overclockers.co.uk/sho...php?t=18460501
    Was planning to replace the faulty D22 diode with "STMicroelectronics-STPS60170CT Diode Schottky 170V 60A 3-Pin(3+Tab)TO-220AB Tube" from Arrow.com.
    Got the monitor disassembled and noticed some brownish discolorations (looks like coffee spilled) on the larger board next to the power board as well as some darker brown stains (looks like rust) on some areas of the power board. Wondering if any of the eagle-eyed experts could take a look at the photos and tell if they see any other issues besides the potential diode problem?
    We do not have an electrical background but can follow instructions to do repairs and able to use soldering iron...
  • steny
    • Aug 2013
    • 14
    Re: Dell 3008WFP Monitor Power Shut Off & Stained Boards
    Here's a close-up of the large board stains:
    • lexwalker
      • Feb 2011
      • 307
      • Malaysia
      Looks like excess flux and/or solder paste. Use isopropyl alcohol and/or contact cleaner to remove them..
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        you dont need to remove them, the problem is not that. Could you take the other sides photo ?
        • steny
          • Aug 2013
          • 14
          Thanks - was wondering if it was flux but there is so much of it - what a mess...
          Have not taken the boards up off the heat sink yet - will see what the other side looks like...
          • Borse2008
            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
            by Borse2008
            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
            • There’s
            07-15-2025, 04:55 AM
          • spike3333
            Dell 3008WFP monitor cycling colors after repair
            by spike3333
            I have a Dell 3008WFP monitor that I disassembled to replace any bad capacitors. After reassembly, the monitor turns on but immediately starts to cycle through simple colored screens; red, yellow, blue, black and white. From my internet search it appears that the monitor has entered a "burn in" mode. I tried all the different button push combinations that were recommended to enter a service menu but none worked. My question is, could this be caused by a hardware issue; an improperly seated connector or something else. Does anyone else have any experience with a...
            08-12-2021, 09:47 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
            by momaka
            03-15-2023, 10:17 PM
