White screen on a Samsung 225BW monitor
  • arjfca
    • May 2013
    Hello
    I had a flickering problem with my monitor and I changed the capacitor.
    Unfortunaly, since I retry- it, I got a white screen. No image at all, even with no cable, I can't have an image of the setup screen
    All capacitors where changed. No bad solder, no reversed capacitors, don't see any solder jump that could cause a short
    Initially, I had replaced (C301, C302) two 680UF by 1000uf. Could this as caused the problem. I did replaced the old 680uf but the problem remain.
    I did check a fuse F301 on the power board and it is OK
    Now, what else could I check?. Any voltage measurement
    Any info appreciated
    Martin
  • 1supertech
    • Apr 2012
    • 384
    Re: White screen on a Samsung 225BW monitor
    Recheck ribbon connection from main board to screen
    • 1supertech
      • Apr 2012
      • 384
      If original caps were 680uf I would of not replaced them with 1000uf you but can go up on the voltage
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • Chrissygizmo
        samsung galaxy ao2s very temperamental after screen replaced
        by Chrissygizmo
        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
        Ive eventually managed to get it on and working but it's very temperamental...
        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
        05-26-2024, 12:05 AM
      • JunkmanJimbo
        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
        by JunkmanJimbo
        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
        Please help. Thanks in advance!
        Yesterday, 11:45 AM
      • Kiberge
        Samsung LH82QENELGC/EN Help needed - Static line on screen
        by Kiberge
        HI guys!
        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
        04-22-2024, 11:28 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
