Westinghouse L2410NM 24" goes black every few minutes for a few seconds
  • markm75
    • Aug 2010
    My screen has begun the age old issue (with a diff screen same type), of going black for a few seconds then coming back on, every few minutes.. when black the blue light at bottom remains lit, so I dont think its a power issue.
    I believe this is another case of what happened to me in 2010 with this thread.
    First it was thought i had bad caps, replaced them, then turned out in end had to get the inverter board for $35..
    I'm guessing inverter again..
    Though maybe I should crack it open and see if there are bad caps anywhere else on this guy.. the main board was recently replaced on this same model.. bad caps on the power supply were replaced on a different lcd (same model in 2010) but I had to get the inverter in the end (the caps caused humming and noise but then suddenly it would go black after those were fixed)....
    Tech, the Universe, and Everything: http://tech-stew.com
    Re: Westinghouse L2410NM 24" goes black every few minutes for a few seconds
    Lets us see the pictures of the boards first.
    • alro7779
      Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
      by alro7779
      Hello, guys!
      I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
      Alex....
      10-03-2025, 05:49 PM
    • ChIck3n
      Dell u2311h 20000 seconds to black issue
      by ChIck3n
      So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
      09-09-2024, 11:44 AM
    • DrankinSAW
      LG 37LG5020 and the tale of 2 seconds to black.
      by DrankinSAW
      I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
      However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
      I bought a new inverter, set to arrive on December 13th
      11-22-2023, 01:10 PM
      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
      09-12-2024, 02:00 PM
      MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
      This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
      09-12-2024, 01:58 PM
