Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
  • markm75
    • Aug 2010
    • 4
    I have a 2 year old Westinghouse 24" screen, i'm hoping to salvage and avoid paying $300 or more for a replacement which probably wont near the quality and resolution at 1920x1200 (mva)..
    For some reason when i turn it on now.. the blue light at the bottom will come on, then go out and flicker essentially.. you can hear buzzing as it tries to get power.. the screen never does come on to show an image though during any of this..
    I'm not sure what to look for if i open it up.. i'm guessing maybe the power supply board is bad ($50 on ebay).. or perhaps something simpler.. i have a voltmeter i could use to test it.. i have some minor experience in soldering as well.. but not much in the way of things like capacitors and fuses etc..
    Any thoughts as to what it might be..?
    Tech, the Universe, and Everything: http://tech-stew.com
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
    Start by posting clear focused pictures of all your boards (top down view - both sides) after reading
    https://www.badcaps.net/forum/showthread.php?t=1868
    --- begin sig file ---
    --- end sig file ---
    • markm75
      • Aug 2010
      • 4
      I was going to, then upon looking at the power supply board I noticed one of the caps is bulging.. fortunately my work location has some people to help out so we are replacing that cap and going to try again..
      The power supply board was making a high pitched humming sound before.. hopefully this is the ticket.. I might also just replace the whole board if this doesnt fix it.. or post some pictures if all else fails.
      • retiredcaps
        • Apr 2010
        • 9271
        The power supply board was making a high pitched humming sound before... I might also just replace the whole board if this doesnt fix it.. or post some pictures if all else fails.
        That could be the bulged cap venting making that high pitched sound.
        Don't buy another board if replacing the cap doesn't work until others here get a chance to help.
        • retiredcaps
          • Apr 2010
          • 9271
          I forgot to add that you should NOT run out to Radio Shack and get a replacement capacitor. The capacitors sold there are general purpose use and not suitable for these type of applications.
          A list of suitable capacitors can be found at
          https://www.badcaps.net/forum/showthread.php?t=2280
          Edit: Good luck on the repair and report back.
          • Renesis13
            • Sep 2010
            • 12
            I'm brand new to the forum but this post is describing exactly the problem I have, with the same model monitor. To the OP, I hope you don't mind me adding my problem to this thread!
            Yesterday, I discovered a bad outlet in another room and today I flipped the circuit breaker off to get ready to replace it. It turns out the breaker was labeled wrong and flipped the power to my office off instead. When I turned it back on, the monitor would not come back on. When I plugged it in, it would just buzz (quiet, high-pitched), then the power light would flicker and the screen flashed and then nothing.
            This is a 2 year old monitor that I purchased from my last company when I left a few months ago. Since a comparable monitor would cost me nearly $400 to replace, and since the symptoms sounded like a power supply and not screen problem, I really didn't have a choice so I started the task of opening it.
            I am a total circuit board noob (aside from soldering a few things here and there like an xbox mod chip), so I didn't see anything wrong with the power supply until I read this thread. Now I notice that one of the capacitors is indeed bulging and slightly leaking.
            Should I do as the OP and try to replace this capacitor and see if that works? Or just search for a replacement power supply? I've posted other pictures of the components for reference. Any help is sincerely appreciated!
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              The design of that board kinda sucks from a technicians point of view. You got to remove the heatsink to get to that cap. Once you get to it, I would change all of them on that side of the board. Not really saving any money by changing one. Remove all doubt and change em all. They should cost you about $5.00 US. Have fun with it and take your time.
              • jetadm123
                • 2169
                You definitely have a bad cap there. It's hard to tell from the photo, but if there's enough headroom between the top of the cap and the heatsink, you may be able to "wiggle" them out using some long nose pliers. Make sure you use solder wick to soak up all the solder holding the cap to the circuit board before you attempt this. Replace ALL the caps as you only want to do this once. And yes, I agree it is a terrible design!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Like everyone has said, replace them all. All the caps in the sink heat area are subjected to a lot of heat from the 3 transistors/FETS. Heat kills caps.
                  Follow PlainBill's instructions on how to order caps at
                  https://www.badcaps.net/forum/showpo...33&postcount=2
                  Pay attention to the correct size comments. You don't have a lot of room in the heat sink area.
                  • jetadm123
                    • 2169
                    Oops! I forgot to mention that you can probably leave the big cap (the one lying on it's side) alone, since these rarely fail.
                    • markm75
                      • Aug 2010
                      • 4
                      Yeah, thats what i did, well, i had help, i probably could have replaced them, but at my business we have guys that do this stuff all the time.. so he bent the one fin back and removed the bulging cap and replaced it, also replaced a few others to be safe too, as mentioned.
                      I could have replaced the board for $50, instead, in my case, it was free..
                      However, once i did this, the unit wouldnt power the screen.. so i tested with the ohm meter on the inverter board.. found that volts werent getting through the whole board..
                      So online i found the inverter board for $35 shipped, with coupon code.. replaced it, now everything works..
                      Total cost in my case.. $35
                      Better than $300-$450 for a new one/diff one
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        If you have the non working inverter board, it would be interesting to see if you have any blown fuses or shorted transistors on it.
                        • Renesis13
                          • Sep 2010
                          • 12
                          Cool, thanks for the help. I will see if I can disassemble the heat sink tonight and try to remove the caps. Will I need to do anything special (like on a processor) for reinstalling the heat sink?
                          markm75 - Sorry for my ignorance, but what is the inverter board? I did a google search but couldn't figure out what in my specific monitor the inverter board is (but I'm guessing it is the tall boar on the right?) Where did you find this replacement part once you discovered it was bad?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Possibly. The transistors may need some artic silver or similar type of compound. I believe in this video Maxxarcade (who is a member here)
                            http://www.youtube.com/user/Maxxarca.../2/SoL1k8Jk_Z8
                            talks about a special compound for mounting audio transistors.
                            Yes, it is the tall board.
                            • Renesis13
                              • Sep 2010
                              • 12
                              Alright, I have some new pictures and I'd like to know how screwed I am.
                              First of all, I took a closer look at the heat sink, and it looks like there is no way to completely detach it from the transistors before removing the transistors from the board, since one of the screws goes all the way through two of them and is butted up right next to a cap under the heat sink.
                              I'm pretty sure removing all of those transistors and correctly reinstalling them would be beyond my ability.
                              Secondly, I'm worried about the cap on this other board, it looks like it's slightly bulging (but I haven't had problems with this monitor prior to this power problem).
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                BTW, please don't put inline pictures into the text. We can click on what we want to see in a bigger image.
                                Hmm, if no one else has ideas, I guess you can try and bend/pry just enough of the heat sink back to replace one bad cap and leave the others alone?
                                Yes, those are bloated and bad too. They are Capxon KF series made in 2007 week 11 (C711 code).
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Do you have any friends good at electronics and soldering? If yes, offer a 6 pack in exchange for soldering.
                                  • Renesis13
                                    • Sep 2010
                                    • 12
                                    Sorry, I thought it was suggested in the image posting tutorial you linked to? (for referring to specific pictures)
                                    At least they will be easier to replace. Can you tell me what "bad" might mean in this case, assuming this damage was not recent (and the monitor was working fine before)?
                                    Thanks again for your quick responses.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Inline is optional, but not preferred. It slows down the loading of a page while huge images are loaded.
                                      Bad meaning that these 2 capacitors are malfunctioning which makes the other components work harder. When they work harder they are bound to fail.
                                      Think of it this way. You have a brake on each wheel of the car. Now imagine 2 of them not working properly (bad). Your car will still stop, but the other 2 have to work so much harder. Not to mention the other extra unneeded stress on your joints, structure, etc. With this extra stress, these components will fail sooner than necessary.
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        replace those 2 small ones too- defintiely
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
