Re: Broken Samsung 2493HM - blinking LED
And the above was done using the power button on the edge of the monitor. On/off power switch next to the power plug was set to 'on'.
No worries about stepping away. I stepped away from this project for three months.
With main board connected, PS_ON fluctuates between 0 and 1 (hard to tell exactly with my digital meter), standby still steady at 5.23v, and the big cap is still 162vdc.Leave a comment:
Jetadm123, can i use the on/off switch on the power supply instead?Leave a comment:
You will need to verify that the 3-5V signal from the mainboard is present to turn on the the power supply. Look for this voltage at the PS_ON point, while pressing the on/off button. I'm going to have to step away for a while.Leave a comment:
With main board and inverter board connected, the big 82uf cap is still reading 162vdc.Leave a comment:
Good. You've verified that the 5V standby circuit is working. Now, you have to verify the PFC circuit is working. Connect the mainboard to the power supply. Press the on/off button and the voltage across the 82uf 450V cap should rise to approx. 390VDC.Leave a comment:
I made more voltage measurements this morning, and found the following:
5.23v steady on standby with no jumper attached, no main board or inverter board attached;
162v on the 82uf big cap.
Retiredcaps, as to the IC801S, there is no part number. Maybe there was one there once upon a time. There is however a spot where it looks like it may have become hot.
As to the diagram, it is highly likely I missed something but I am not convinced it's the same as what I've got. For instance, my power board has two fuses coming off the AC connector, and I could only find one on the diagram.Leave a comment:
So you need to find out if you have the 5.2Vdc or not as suggested by jetadm123.
This diagram should match your board.Attached FilesLeave a comment:
What is part number ICP801S? It is on the backside 8 pin IC.
PS. Nice pics thanks to the California sunshine.Last edited by retiredcaps; 03-09-2013, 08:51 PM.Leave a comment:
Without the main board and inverter connected, you should still at least see the 5.2 V standby voltage. What voltage are you seeing across the the large 82uf 450V capacitor? It should be approx. 170VDC.Leave a comment:
Hi Retiredcaps,
I did some more troubleshooting on my monitor this morning, and the results were not encouraging. I was unable to read any voltage readings on either the 5.3 side or the 24v side.
The inverter and also the main board was not plugged in. Was I doing this correctly?
I have attached photos of the power board, complete with the jumper resistor. I did not have a 1k available, so I used a 2.7k. Is that an acceptable alternative?
I should also say that the sk763 7 pin ic has also been replaced; they were inexpensive from Hong Kong and I ordered some spares over the Christmas holidays. And I have spares if anyone needs one.
There was also much glue on the board, and most of it has been removed.
Both white fuses have been checked for continuity.
CM851 and CM852 next to the 24v connector at top right were originally 1000uf 35v but due to a shortage have been temporarily replaced with 1000uf 25v. I'm thinking that's ok for the short term.
All suggestions appreciated.Leave a comment:
Thank you retiredcaps - these are some good suggestions. My next moment of opportunity will be this weekend. At that time, I'll put the transistors back onto the power board and will also post some photos after I check for 5V.Leave a comment:
The Fluke 27/FM has a relative button which you can use to compensate for the resistance in the leads. That should put the resistor reading closer to 0.22 ohms.
2) If you disconnect the main board, do you get steady 5V standby?
3) With the main board disconnected, if you jumper 5V standby to PS_ON using a 1K ohm resistor, do the rest of the voltages come up (please report them)?
4) Can you post a picture of the main board? Also post pictures of your power board.
5) The readings for QM802 and QM803 suggest they are not shorted.Last edited by retiredcaps; 03-04-2013, 07:33 PM.Leave a comment:
Hi List Members,
I am in the very same position as Froleo above. Over the Thanksgiving holidays, I acquired a Samsung 2493HM which also has a fast blinking LED power light, but no display whatsoever. I find myself at a somewhat disadvantage because I discovered that someone had already been playing around with the BN44-00195A power board in that there were several odd capacitors which had been substituted. They probably were looking for the quick fix of just changing out a couple of caps.
Since then, I have changed all the caps to the recommended Panasonic FR, FM or FC series.
In Newbie's post above, he writes about the fusible resistor facing the two transistors. The color code is red/red/silver/gold, which according to my interpretation is .22 ohms. My reading is .5 ohms. Could this be the culprit?
And now on to QM802 and QM803. I removed them from the circuit - I found this was most easily done by removing them complete with the heat sink - and my readings were open across all combinations except for the center and right pins (when looking at it from the front side) which read 2.7m ohms.
I can post photos of the power board if it would be beneficial, although at this time the transistors / heat sink has been removed.Last edited by LAS; 03-04-2013, 01:19 PM.Leave a comment:
If you have got your solder iron already, unsolder the components with the glue on them and scrape off those remainding glues on the board. if you have a multimeter, measure the transistors qm802 and qm803 for short , out of the board. And also whether the resistor facing it is fused(open).Leave a comment:
I have a Samsung 2493HM monitor that has gone bad. The LED light is blinking, but there is no picture on the screen.
I had the same issue when the monitor was still under warranty,
and I had the monitor fixed at a service center. They replaced / fixed the inverter board.
I'm assuming its the same issue this time around.
After reading a bit, I found out that the most common issues are bad capacitors.
I opened the monitor to check the inverter board for bad caps, but couldn't find any caps that were visually damaged.
(I've attached some pictures of the board.)
I have no experience with soldering whatsoever, and I currently have no soldering equipment.
I'm considering picking up a cheap soldering iron and a kit from ebay just to try.
After watching some YouTube clips it seems managable.
http://www.ebay.com/itm/Repair-Kit-S...-/330549799415
Do you think the capacitor might be the problem, even though they are not visually damaged?Tags: None
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have...
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
