Broken Samsung 2493HM - blinking LED
    replied
    Re: Broken Samsung 2493HM - blinking LED
    That is going to be tough to trace out the PFC circuits then.
  • LAS
    replied
    Budm, I'm thinking it isn't. I looked no further when I saw that my board has two fuses next to the AC plug and the schematic only shows one.
    replied
    Notes:Please verify that the sch I posted matches your board.
  • LAS
    replied
    And yes, black cap is a Panasonic FR series.
  • LAS
    replied
    Thanks retiredcaps. The next couple of days are pretty hectic but should be able to investigate all of the above Saturday.
  • retiredcaps
    replied
    Looking at the back of the pcb, I notice there may be some solder crack rings in LP801S. As a longshot, you might want to reflow that entire PFC area with some fresh 60/40 solder on anything that looks remotely bad.
    Anyway, that should be enough ideas for now.
  • retiredcaps
    replied
    Is that black cap just above the 00195A a Panasonic?
  • retiredcaps
    replied
    Originally posted by retiredcaps
    What is part number ICP801S? It is on the backside 8 pin IC.
    Using the schematic that budm provided, ICP801S is TDA4863G which is the PFC IC as per
    https://cdn.badcaps-static.com/pdfs/...17ea6ca5bc.pdf
    Refer to figure 2 in the datasheet. Using pin 6 as ground, CAREFULLY report all the DCV readings for pins 1-8 wrt to pin 6 (GND). Any slip of the probe will cause
    For stuff like this, I get my sharpest probes out and wear safety glasses.
  • retiredcaps
    replied
    Hmm, I failed to notice earlier that the power board is a BN44-00195A. There are several "usual suspects", I believe, for this board. I'll have to review the threads to see what they are.
  • retiredcaps
    replied
    My guess is that BM801 is a bead from the picture? I'm not sure what the M stands for. A bead would measure around 0.1 ohms or less.
  • LAS
    replied
    Can identify what sort of device BM801 is? It is right next to the big 82uf cap on the power board. It is reading .2 ohms, about the same as the meter's probe resistance. Perhaps I'm back in the game??
  • retiredcaps
    replied
    Originally posted by LAS
    Datasheet is attached...can someone provide pointers on how I can test them?
    You can see if pins are shorted using every possible combination.
    In the PFC section, I think there has been a handful of cases where the 431 was bad causing the PFC not to work properly.
    PS. I believe 431 = KIA431 = TL431.
  • LAS
    replied
    It looks like there are a fair amount of KIA431A diodes on the power board. Might be a good exercise to test them all.
    Thanks all.
  • newbie1
    replied
    Long shot. How about removing TM801 from the board and check whether the 'glue' is still stuck on the board? I had previously had that ONCE. The 'glue' shorted the path of the pins below that TM801 and after removing (scraping) it, the monitor came back to live.
    However, i am still having 3 of these board which i have given up trouble shooting. This is because all three of them are having TM801 'fused' (burnt). So i ended up buying the whole board but of compatible model. I am having nightmare whenever i receive this particular power board to repair.
  • retiredcaps
    replied
    Additionally, before you spend too much time and money trying to fix this monitor, try to see with a flashlight if the screen is cracked or broken. It would be a shame to get everything working only to find out the screen is cracked. Sometimes, the "flashlight trick" doesn't work and maybe some good old California sunshine might reveal more?
    If the power supply is working via PS_ON (or we supply the 5V DC an 24V DC externally - though I'm not sure how to bypass the PFC), then "jumping" BL_ON (backlight on) will force the backlights on.
  • retiredcaps
    replied
    If the main board is indeed bad due to a proprietary component (like IC300), then it is pretty much impossible to get a replacement part. Or if the eeprom/firmware is corrupt, then it would be difficult to reprogram?
    You can trying tracing the PS_ON pin on the main board to see where the circuit path goes and check each component. The continuity feature on the Fluke 12B will help you track down which components are in the circuit.
    It might be a transistor that is responsible for switching on PS_ON isn't working or shorted?
  • jetadm123
    replied
    Looks like the voltage regulator output is correct. To summarize, the main board does not seem to output the 3V required for PS_ON. Even if it did, based on you applying the jumper to PS_ON without the PFC starting up, I would agree with retiredcaps that it appears you have problems with both the main board and power supply.
  • LAS
    replied
    F601 tested ok
    IC113: 3.4v, 0v on the short leg, 2.5v.
    I put the jumper back on to test just once more, with similar results. 5v on standby, 3v on pson, and 0v up on the 24v pin.
    I'd believe multiple problems on this monitor. I wasn't the first to crack it open, and who knows what went on before it came to me.
    In the meantime, thanks all for the suggestions.
  • jetadm123
    replied
    Also, try checking fuse F601 at the top of your mainboard.
  • retiredcaps
    replied
    You may have multiple problems.
    1) Jumping 5V standby to PS_ON with main board disconnected should have brought up the other power supply rails. There may be a problem with the PFC section?
    2) Getting a reading of between 0 and 1V DC on the PS_ON pin with the main board connected suggests there is something could be wrong with the main board. The main board, if working correctly, should be sending out > 3V DC (typically).
    3) IC113 on the main board looks like a fixed 2.5V regulator. Measure the 3 pins (including the cut pin) with respect to ground. Report your readings.
    4) Measuring the big cap and PFC section can involve DCV in the 400V range. BE CAREFUL.
    09-07-2024, 05:50 AM
    by momaka
    03-15-2023, 10:17 PM
  • ArchangelGabriel
    Aorus 17G YD laptop, broken display, could not switch to external monitor
    by ArchangelGabriel
    Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
    11-23-2023, 03:55 AM
    09-06-2024, 11:40 PM
