Samsung T240HD won't turn on
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung T240HD won't turn on
    Also with power off, meter on ohms 200 can you test that fuse 301 again and post the result.
    • phx777
      • Dec 2012
      • 24
      • US
      updated the results.
      I thought the main board was the board with all the inputs >.>
      Perhaps it's best to explain everything in Layman's, my knowledge on these things are very limited.
      and I've tested the fuses, they are fine. 0.25 ohms on both
      thanks for all the help!
      • selldoor
        Slow Learner
        • 7870
        Originally Posted by selldoor View Post
        OK With your meter on VDC 20 put the black pin on pin 4 and with the red probe touch
        the other pins and report the results.
        Board needs to be plugged in to the mains. Still take care although you are measuring low voltages parts of the board are still high.
        Originally posted by selldoor
        Not really getting through to you are we?
        The above test is to be carried out with only the power supply plugged into the mains - no other boards for the moment.
        The pins are on the connector CN2 in the same corner that the voltage list is
        That is as Layman as I get but here is a picture
        • phx777
          • Dec 2012
          • 24
          • US
          ahhhh that makes so much more sense, thanks!
          I'll get on it and report back.
          • phx777
            • Dec 2012
            • 24
            • US
            finished testing, as marked, one returned 15v and two returned 5.2v
            all others are 0
            • Rtech
              • Jul 2010
              • 1095
              #26
              So the next step is to connect the other boards,and then take the same measurements again,and see if you still get the 15v and the 5.2v
              • phx777
                • Dec 2012
                • 24
                • US
                #27
                they are close to 0 now. might have seen the 15v jump to 1v a couple of times.
                • Rtech
                  • Jul 2010
                  • 1095
                  #28
                  Looks like it is the Logic Board that is faulty then,you already checked the Voltage regulators on there ??
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    No, He has not.
                    In the picture of the main board, thoughtfully placed upside down! on the left hand side bottom just above the screw hole there is a black square component with 2.5 legs.
                    On it I think it has a part number that has "33" in it.
                    I think it is a voltage regulator.
                    If you read this by retiredcaps you should be able to test it and find others on the board - we will need a better picture preferably the right way up to help.
                    https://www.badcaps.net/forum/showthread.php?p=261329
                    I notice in that picture that the board may be on an antistatic bag? If that is so please be aware that the foil on it is conductive and you should not be doing any tests with the boards sitting on it.
                    • phx777
                      • Dec 2012
                      • 24
                      • US
                      #30
                      that picture of the board is a picture I found off ebay, don't worry I'm not testing it on a antistatic bag.
                      I've read the guide on testing the voltage regulator, I'm not sure what it means by "Put your black probe on a ground screw". Does it mean I can just put the black probe on any large metal object? I'm not getting any readings out of any voltage regulators.
                      • Rtech
                        • Jul 2010
                        • 1095
                        #31
                        The metal part of the VGA or DVI input socket will be fine.
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          Well thanks a lot. Just wasted my time looking at it then. I am off the case.
                          • phx777
                            • Dec 2012
                            • 24
                            • US
                            #33
                            I'm sorry you feel that way. When I uploaded that picture I thought it was a faulty power board so I didnt even take off the main board for a picture.
                            thanks for all your help so far, it was very helpful.
                            I've tested the voltage regulators (not sure if I found all of them). Most of the tests returned 0 except for the ones I marked in red.
                            • Rtech
                              • Jul 2010
                              • 1095
                              #34
                              Find the pin that the 5v would normally come into the board on, and trace the track to the nearest Voltage regulator,obviously you have to do this with the board dis-connected because it is pulling the 5v down.Also Numbers on all, what you think are regulators will be helpful.
                              • phx777
                                • Dec 2012
                                • 24
                                • US
                                #35
                                I was thinking of just buying a replacement board if I can be 100% sure it's the cause of the problem. :\
                                all in all, this was a pretty fun/interesting experience, I am willing to see it to the end if I can.
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  #36
                                  Well there is no certainty that it is the regulators, as other things fail also.BUT from the tests you have carried out,it is very likely to be the Logic.One test you can do,to perhaps set your mind at rest,is as follows,,,,Set up the Power supply ONLY,so you know you have 5v on that,and then plug the Backlights in ONLY(NO other board or lead to the Screen),Then take a 1KΩ resistor and hook it between the 5v pin and the ON/OFF pin on the connector,,,,that should put the Backlights on and shown the Power supply AND Inverter AND Backlights are good.
                                  • phx777
                                    • Dec 2012
                                    • 24
                                    • US
                                    #37
                                    by connector do you mean the connector that connects the ON/OFF button to the logic board? how do I know which pin is the ON/OFF pin? There are two markings on the connector. There is a green dot on the connector, and a black mark on one of the cables.
                                    or did you mean the ON/OFF on the power board?
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #38
                                      on the Power Board, as that is the ONLY one you will have on !!!!!! again NO Logic BOard, Power supply ONLY with just the Backlights plugged in NOT the other lead that goes to the screen...
                                      • phx777
                                        • Dec 2012
                                        • 24
                                        • US
                                        #39
                                        ah ok thanks for clearing that up, gotta go buy a resistor now. So basically, it is to trick the power board into turning on to giving power to the backlight right?
                                        • Rtech
                                          • Jul 2010
                                          • 1095
                                          #40
                                          Correct...you could as an alternative put 3V from a battery between any of the GND pins and the ON/OFF Pin....same effect.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
