was using it last night as usual then it just turned off, there werent any strange sounds or anything. it just went black and the power indicator light faded away. now it doesnt turn on, the power cord works fine, and I've tried turning it on with the remote as well.
is this because of a faulty power board? does anyone turn how to actually disassemble this?
thanks!
EDIT: I managed to get it open, for people wondering how:
there are two visible screws that you have to undo first, then you must take off the stand. (this is where I got stuck on earlier). While the monitor is facing down, what you want to do is lift the stand itself really hard while pulling on it.
after the stand comes off there are two more screws to be undone. then you have to use a flat head screw driver to ply off all the tabs on all sides. I worked my way around, there were a lot of loud popping noises. and I broke one of the tabs. but now it's open.
I also managed to take off the power board, it's got some solid white substance everywhere, is this suppose to be here? or is this why it broke?
edit2: turns out it's suppose to be there. so... any way to test if this thing still works or not?
thanks!
