Hanns G HG281D - Starting to go black and back to normal!
  • broadbandsamurai
    • Dec 2012
    • Poland
    I have 2 Hanns G HG281D LCD monitors. Both are having the same issue. They're not both hooked to my pc, just one. The other was my father's.
    I dunno if it's important, but in Poland we are sitting at 230 V AC, 50Hz main line voltage. The power supply output to the monitor is the same I'd imagine, no matter where you are.
    When I turn it on, it goes normal for a few seconds. Then the screen goes black, after a few seconds it goes back to normal, then back to black again.
    It alternates between black screen and normal screen in random intervals and each state also lasts a random amount of time sometimes the black screen can take up to 5 min. or more to go to normal.
    I've often read it's the capacitors in those monitors. My father is tech- and electronics-savvy so I'm sure we can repair it, however, we need to start somewhere, and that's where we are clueless.
    So, what do you think the problem is? How to we go about it?
    If it's the capacitors, what kind of capacitors do we need and which ones (as in on what board? There's a few boards in there. Logic board, power supply board, etc.)
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Hanns G HG281D - Starting to go black and back to normal!
    First thing is to type HG281D into the search engine and read some of the threads
    This one seems to cover most problems and tests.
    https://www.badcaps.net/forum/showth...ghlight=HG281D
    It probably is dried out caps - one problem is they are hidden behind a heatsink.
    When you are ready to proceed you will need to post clear pictures so we can help troubleshoot this with you.
    The 220v mains is important please can you update you profile and put it in there
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attachm...1&d=1290283049
    https://www.badcaps.net/forum/attachm...7&d=1280167246
    • beetle1303
      Sony KD-65X7000E - Screen double images for first few minutes then back to normal
      by beetle1303
      I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
      Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
      1) On power up - display double images, and flicker once every few seconds.
      2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
      3) Leaving on for few minutes, power off and on again will repeat the same...
      03-11-2023, 02:07 AM
      Linear Garage Door Opener Control board took a crap install a new control board back normal
      I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
      02-08-2025, 06:52 AM
      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
      09-12-2024, 02:30 PM
      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
      HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
      09-06-2024, 08:10 PM
