Samsung T220 Syncmaster Monitor
  • Sandancer
    • Nov 2012
    • England
    Hi there folks I found this monitor outside of my neighbours the other day,
    it looks like a common fault with these. But I have checked the PCB and the capacitors look ok I have bought 2 1000uF 25v 105C capacitors from maplin but something is telling me that it aint them. Can anybody put me the right direction to fixing this monitor. I aint very good with Tech terms so as easy as it can be please...
    Thank You
  • Lumberjack777
    • Dec 2010
    • 464
    Re: Samsung T220 Syncmaster Monitor
    OK. First of all we need high quality pics of the front and back of the board. Use the manage attachments option to upload them. Then we need to know the symptoms. Does the LED light up when you press the on button? If it does, can you see a faint image on the screen when you shine into it with a flashlight? We just need to see the board, and know the symptoms. Thanks. ~L-J-7~
    • SuperDuty
      • Mar 2011
      • 299
      • France
      What's the problem exactly ?
      I've just fixed one I found in the dump. Topic with pictures here : https://www.badcaps.net/forum/showthread.php?t=24215
      • Sandancer
        • Nov 2012
        • England
        yep those pics look just like mine, I have replaced the capacitors still doing the same, when i switch it on the screen comes on for less than a sec then goes off
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Maplins rarely have stock of Low ESR capacitors needed for power supply.
          The ones you got may not be up to the job.
          • SuperDuty
            • Mar 2011
            • 299
            • France
            Original ones were four SamYoung LXZ 25V 820uF and two NXE 16V 1000uF, both rated at 105°C. They weren't obviously bad on mine, but I've replaced the LXZ with Rubycon ZL since I had some with the same specs.
            I haven't replaced the smaller caps since they weren't part of the problem.
              09-07-2024, 05:50 AM
              by momaka
              03-15-2023, 10:17 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
