Samsung "BlinkMaster" 206BW Screen Flicker, Requesting cap selection help.
+ More Options
Posts
  • DWChris
    • Sep 2012
    • 21
    I have a Samsung "BlinkMaster" 206bw with flicker of death. I have attached a picture with the caps noted. All are CapXon.
    1. 470uf 35v
    2. 1000uf 25v
    3. 470uf 25v
    4. 1uf 50v
    5. 22uf 50v
    6. 120uf 450v
    I am looking at the caps in the attached excel document.
    Have I chosen sufficient replacements?
    Thanks,
    -Chris
  • Mr Bill
    • Nov 2011
    • 648
    Re: Samsung "BlinkMaster" 206BW Screen Flicker, Requesting cap selection help.
    It should work but you don't need to replace the big 450v cap. I've recapped a few of these monitors and never replaced the big one and never had any issues.
    • selldoor
      Slow Learner
      • 7870
      Whilst Mr Bill has already said you probably dont need the BIG cap the one
      you have picked seems to have odd descriptions.
      It does say through hole but it also says snap in.
      The datasheet indicates only short legs so if it is a short leg snap-in
      You would have to solder legs onto it or use the existing legs -cut off. One problem might be that they are often fatter than a normal cap so you would have to check the space available.
      • DWChris
        • Sep 2012
        • 21
        Yeah its the same as the last monitor I fixed just a different value. I cut the leads on the old cap and just soldered the new cap to them.
        Thanks Guys.
        • DWChris
          • Sep 2012
          • 21
          Monitor fixed. Thanks guys This forum is great.
            Did you replace the big cap? That can cause the blinking sometimes.
            • DWChris
              • Sep 2012
              • 21
              Yeah I just replaced them all for good measure.
              • mockingbird
                • Dec 2008
                • 5484
                Did you have to extend the leads somehow for the primary cap, or were they long enough that you could bend them into the hole? Because the one you picked is snap-in... Good choices otherwise... Parts you picked are top notch.
                • DWChris
                  • Sep 2012
                  • 21
                  I just cut the leads off the old cap and left them on the board then soldered the new cap to them.
                  • DWChris
                    • Sep 2012
                    • 21
                    New problem I initially diagnosed it as bad caps. I replaced all the caps on it and it worked for a bit. Now I get a very fast screen flicker. I rechecked and re soldered all my caps and am still getting the same symptom. How should I proceed? leaving the unit on for a few minutes and it fades out completely and flashes on very dim every 5-10 secs. then after a few more minutes nothing.
                    • selldoor
                      Slow Learner
                      • 7870
                      Do you have any spare bulbs an old monitor or laptop you can use to substitute bulbs.
                      • DWChris
                        • Sep 2012
                        • 21
                        I have some bulbs I can pull from another monitor.
                        • selldoor
                          Slow Learner
                          • 7870
                          You do not need to pull completely down as far as bulbs -(easy to break) just try and get to the panel.
                          If the plugs are the same you can simply try one or two in place of the
                          206bw bulbs and see if the flickering stops/changes.
                          Have you tried reducing the brightness and changing the resolution?
                          What does the power light do when the screen flickers.
                          • DWChris
                            • Sep 2012
                            • 21
                            Resolution change/adjusting brightness/ switching input from analog to digital does not change symptom. Power light is on solid like it should be in normal operation.
                            • Haggai
                              • Nov 2012
                              • 4
                              • Israel
                              I intend to try fix my 206BW monitor in a few days. (It blinks, so I guess the problem is with the three capacitors marked 2,2,3 in the image in the first post)
                              Is it necessary to discharge any capacitors prior to desoldering/soldering the faulty capacitors?
                              If it is, how do you recommend I do that?
                              Thanks.
                              • selldoor
                                Slow Learner
                                • 7870
                                Haggai - if the set has been un plugged for an hour before you start the caps should have discharged. You can check by testing across them with a multimeter set on
                                200 vdc. If they read 5 to 25vdc discharge them with a 1k or 2k 25w resistor. (Some just use a screwdriver! -less than 5v just go ahead and desolder it wont shock you.
                                • Haggai
                                  • Nov 2012
                                  • 4
                                  • Israel
                                  Thanks.
                                  What about the other caps? Specifically the 450V one.
                                  If I don't short it and don't desolder it I don't have to worry about it? Can't it still provide voltage/current to the circuit part I'm touching?
                                  • Haggai
                                    • Nov 2012
                                    • 4
                                    • Israel
                                    Okay, never mind, I just measured the voltage across the capacitors, and none (including the 450V) had more than a couple mV on them. The 450V had 55mV, I guess that's safe...
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Yes - quite safe
                                      • Haggai
                                        • Nov 2012
                                        • 4
                                        • Israel
                                        Yayyy it worked!!
                                        Now let's hope those Nichicons I put there will hold better than the CapXon that bulged...
                                          09-07-2024, 05:50 AM
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
