How to Fix DCLCD DCL9B 2 Seconds to Black
  • ZappedAgain
    • Mar 2011
    • 49
    Thought it might be useful to post a successful repair procedure for this monitor.
    The monitor was exhibiting classic 2 seconds to black symptoms. Turn it on and you would get a picture for 1 or 2 seconds then it would go Dark.
    I recapped the board using all panasonic low ESR capacitors. Everything on the board was replaced except for the (3) 1uf caps.
    Problem was gone. Monitor was tested for 24 hours with no problems and a nice picture.
    A picture of the front of the board is attached with the capacitor values labeled.
    Good luck if you have the same symptoms and monitor.
  • Rick_1234
    by Rick_1234
    Good evening, gentlemen.
    Things I tried
    06-22-2024, 04:44 PM
  • sew333
    Pc shutdown, monitor flickered with no signal after 10 seconds
    by sew333
    My pc:
    10850K stock 4800mhz stock Kraken X73 good temps
    2x16 GB DDR4 GSKILL 3000mhz XMP
    Seasonic Tx-850 Ultra Titanium
    Gigabyte Rtx 3090 Gaming OC
    Aorus Z490 Pro Gaming
    1 TB SSD
    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
    Power...
    02-22-2022, 10:27 AM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • kerberos137
    Sony xbr-65x930e faded to black; now has backlight but no picture
    by kerberos137
    Hopefully someone can help me out. This tv was working perfectly until a few weeks ago. At some point, the TV just faded to black, but sound continued playing. It almost looked like smoke on the screen as it faded from the bottom left corner toward the top right. Took only a second or less, but wasn't instant. After restarting, it turned back on and worked fine for another day or two. Then it happened again more or less the same way, but in a slightly different direction, again with sound continuing. I thought it was working fine after another restart, but looked a bit dimmer than before. Then...
    11-29-2022, 05:40 AM
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
