suyama mj7cna screen goes blank
  • chrisjevenden
    • Nov 2012
    Hello, I'd like some suggerstions please.
    The above monitor obviously has a hardware problem. When connected to a desktop, the power light is on green (indicating a signal is being received). A dim screen display will appear perfectly rendered for less than a second and then goes completely blank. If the unit is then turned off at the power and on again after a few seconds the display will again appear briefly.
    I have connected the screen to 2 different PCs and the same fault is in evidence.
    I am reluctant to put it in for recycling and buy a new one when it seems most of the unit is working fine.
    Suggestions please?
    Thanks Chris
  • Rtech
    • Jul 2010
    • 1095
    Re: suyama mj7cna screen goes blank
    From the description,the problem is certainly on the PSU/Inverter Board PROVIDED that the Lamps themselves are ok.Your first task is to open the unit,take some photos and attach,using the manage attachments section under 'Go Advanced' below.
    You may well spot bulging capacitors as soon as you inspect the board.
    • sabre504
      • May 2010
      • 449
      I have dealt with a few of these and as long as the lamps are ok
      i usually find that a full cap replacement sorts them out ,
      the caps may well look ok but are low quality .
      Also i would resolder the transformers too .
      But as Rtech said open it up and post pics in case yours is using a different type of psu
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • Kalman27
        Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
        by Kalman27
        We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
        We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
        I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
        Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
        06-17-2025, 05:52 AM
