Olevia 327-S12 Monitor, vertical lines fade out backlight on
  • kschultz
    • Feb 2012
    I am looking for some help on this Olevia 327-S12 monitor.
    Blue light is on, press power button, display shows various color vertical lines which fade out after about 3-4 seconds. The backlight comes on and stays on. I see no visible bad capacitors. I have used DMM to verify voltages on power supply board, connector CN903 has 12VDC on pins 1 & 2. Connector CN904 has 5.15VDC on pins 4,5, & 6. These voltages are also getting to the system board connectors CN3, CN4, & CN5.
    I have checked all fuses I can find and they seem fine. I have checked the output transformers and they measure 1.1K ohm and all measure the same.
    This is my first post so any assistance would be appreciated.
    Thank you.
  • Stanley1843
    Screen Display Vertical Multicolor Lines
    by Stanley1843
    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
    06-29-2024, 11:54 AM
    by momaka
    03-15-2023, 10:17 PM
  • Falki
    Colorful LCD Vertical Lines on Samsung ue55es8090
    by Falki
    Hello there, ive recently found an older 55inch Samsung SmartTV.
    Sadly it has vertical lines at the left and one line in the middle-right.
    I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
    I have factory resetted the TV as well but also with no luck.
    I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
    A similar issue has been posted as well but also with no actual response ...
    08-12-2025, 04:19 AM
  • visionbluedemon
    Help. Sony kd-65x85dj vertical lines
    by visionbluedemon
    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
    tried blocking LC lines too, but same results
    is it lcd panel issue or tcon board issue?...
    07-25-2025, 04:56 AM
  • jackster
    Samsung Curved monitor C27FG70FQU with garbled vertical lines on startup
    by jackster
    I acquired a faulty curved Samsung C27FG70FQU which has the quite common problem of just showing weird vertical lines for a while after a cold boot.
    The issue is pretty bad with this one and it takes about 15 minutes before things normalize and a proper image is displayed. Once a proper image is shown it will work 100% until the display is shut down or put in standby for a while and allowed to cool for a bit.
    Even though this seems to be a quite common issue I haven't really found any information regarding what the root cause is and how to fix it. There is this video...
    02-13-2023, 01:56 PM
