Scepter x20WG-naga 2 seconds to black.
  • Halosheep
    • Oct 2012
    • 5
    Hey everyone, read around the forums and everything, but due to my limited knowledge I figured I would probably need some help!
    I know the basics, how to solder/desolder and I know my parts pretty well, but I'm not very good at the troubleshooting part!
    Anyway, onto the actual technical end of things:
    Recently my x20WG monitor just started going black for no reason, image was still visible with a flashlight or other (followed all these steps) and I don't know where to start. I took it apart (what a hassle) and now have the board out, and there are some burn spots on it. I have some pictures, hopefully of adequate quality.
    Hope you can help!
  • Rtech
    • Jul 2010
    • 1095
    Re: Scepter x20WG-naga 2 seconds to black.
    The Purple capacitpr on the right hand side ,standing on its own,looks 'bulged'at the top, and may well be the cause of your problem ??
    • Halosheep
      • Oct 2012
      • 5
      It does appear a little bulged, what would be a good replacement 150 μF/25V capacitor?
      Rather, which company would you suggest as a replacement?
      • tron
        • Apr 2009
        • 47
        Change the green SamXon GF ones aswell
        • retiredcaps
          • Apr 2010
          • 9271
          Yes, the Samxon GF are "known" bad series of caps.
          Most recommend digikey.com and use Panasonic FR/FM or FC series. An example is provided (regulars may skip)
          https://www.badcaps.net/forum/showpo...84&postcount=3
          --- begin sig file ---
          --- end sig file ---
          • mu2
            • Oct 2009
            • 217
            I had the same problem with that monitor. That same cap was bulged.
            I substituted a 220 mf Panasonic FM series of the same voltage until I could get the correct value.
            My problem turned out to be a bad lamp.
            I have some spare lamps with plugs attached for testing. The monitor uses four bulbs and the bad one was number three.
            Good luck - hope your problem is only the capacitor.
            Mike
            • ctrlx
              • Feb 2013
              • 4
              Where are replacement lamps available from, if that is what my problem turns out to be.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4977
                • New Zealand
                I bought some from these guys once: http://myworld.ebay.com/plazmo_industries
                Your problem could be something else though. You said in your other post you replaced all the capacitors already. Did you use high quality replacements with correct ESR? If not, they could be a problem too.
                -David VanHorn
                • mu2
                  • Oct 2009
                  • 217
                  I just ordered a lamp for that monitor from plazmo industries. The size I ordered is 2.4 mm x 445 mm. It might be 446 mm - tough to measure that tight.
                  Price was $8 + $4.99 shipping. Ordered it through their e-bay store.
                  Mike
                  • ctrlx
                    • Feb 2013
                    • 4
                    The Sceptre monitor I have has a display panel from Optronics, model M201SP01, I located the Product Specifications for it, for those who are interested:
                    • ctrlx
                      • Feb 2013
                      • 4
                      I was able to get back to the Scepter X20WG-NAGA to do further testing. The board was recapped and was functioning properly. Which lead me to believe that one or several of the CCFLs were sick and dying and would force the board on the monitor to over drive and then shutdown. While the CCFL fixtures were still mounted in place within the monitor, I used a separate single CCFL Inverter (I just happen to have one) to power the four CCFLs one at a time to determine which CCFL was bad. It turned out that two were okay (not the best), one was poor and one turned on red-orange.
                      I then disassembled the monitor, removed the CCFL fixtures and measured the CCFLs (length and diameter) for replacements.
                      Required: 4 - 2.4mm X 445mm
                      I replaced all four at the same time. For the small price of the CCFL it's better to just go all fresh.
                      Reassembled and powered up. Now the picture has beautiful crisp white and the colors are also more vibrant and crisp.
                      CCFLs were purchased from:
                      Plazmo Industries, Inc
                      7735 S. 134th St., Ste 101
                      Omaha, NE. 68138-3717
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4977
                        • New Zealand
                        Looks like you've done well
                        Next to crap caps, it seems crap lamps are the biggest problem with LCDs.
                        badlamps.com anyone?
                        -David VanHorn
                        • ChIck3n
                          Dell u2311h 20000 seconds to black issue
                          by ChIck3n
                          So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                          09-09-2024, 11:44 AM
                        • DrankinSAW
                          LG 37LG5020 and the tale of 2 seconds to black.
                          by DrankinSAW
                          I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
                          However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
                          I bought a new inverter, set to arrive on December 13th
                          11-22-2023, 01:10 PM
                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                          09-12-2024, 02:00 PM
                          MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                          This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          09-12-2024, 01:58 PM
                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-07-2024, 05:00 AM
