low voltagw on 150uf 450v cap?
  • capted
    • Feb 2011
    • 30
    Hey guys, I have a question. I keep reading about checking the voltage on the big cap for an lcd power board. I am reading 60 volts instead of 160v on some test boards I have. Where would the problem be if I am not getting the 160v? I have 120v input also. It is a dell sp2008 monitor I am working on. Thanks for any info.
  • mariushm
    • May 2011
    • 3799
    Re: low voltagw on 150uf 450v cap?
    Make sure you test DC and not AC on the big capacitor.
    See if the bridge rectifier is bad.
    If the power supply has a PFC circuit, the PFC controller may be bad - and you should have about 300-400v on that 450v capacitor.
    If there's no PFC you would have 110v x 1.41 = ~ 160v or 230v x 1.41 = ~ 330v
    • capted
      • Feb 2011
      • 30
      am I correct, the bridge is the 4 pin big diode on the heat sink. I ask because I get 120v to one pin and 60v on two other pins.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        You should get about 120v AC across the pins marked with the '~'
        You should get about 160v DC across the pins marked '+' and '-'
        If this has PFC, there usually is no filter capacitor directly after the bridge rectifier, so there might be a fairly large amount of ripple (which you might be measuring)
        Muh-soggy-knee
          "I am reading 60 volts instead of 160v on some test boards " I think you are using the chassis ground as your ground reference point, that is why you are getting the reading around 60V. You need to use the negative leg of the main DC filter cap as a ground ref point when you are working in the primary side of the power supply.
          And sure you DO NOT TOUCH any part of the primary section with your hands or body.
          To be safe when you work on the anything that is plug into AC, you should plug it into an GFI protected outlet.
          You should make something like this if you are working with AC.
          http://s807.photobucket.com/albums/y...t=DSC00073.jpg
          • capted
            • Feb 2011
            • 30
            I did check the voltage on the legs of the cap. I have some time behind the wheel with testing and not getting zapped!!! I checked the bridge and I get 120 on the two legs and 60v on the other two(fluke 88 meter). I'm thinking the bridge is bad but you guys have way more know how than me.. Oh. all the caps but the big one I changed with nichicons.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Hm, that bridge does sound fishy.
              Do you have extra caps of around the same uF rating and voltage rating (no less than 450v!)? If so try swapping it out. It may be dry. What brand is it?
              Muh-soggy-knee
                "get 120 on the two legs and 60v on the other two(fluke 88 meter)" OK, you are getting 60V at the output of the bridge, not at the filter cap itself, since this unit more likely to have PFC circuit, the + side output of the bridge should be connected to Anode side of the PFC isolation diode, the Cathode side of that Diode will be connected to the + leg of the cap.
                So if you measure at the + side of the bridge, you will not see the 160V due to the isolation Diode. but if the cap is open then I can see why you will read 60VDC on the cap itself, but the cap has to be completely open and there is no other cap in the circuit to let the voltage charge up to peak.
                So can you verify if the setup is like what I indicate above?
                • capted
                  • Feb 2011
                  • 30
                  I have some spare power boards that have that size cap from a few screens that were cracked. I will take the cap out and try that...
                  • capted
                    • Feb 2011
                    • 30
                    I do think it is that set-up...
                      Then start tracing all that path from the + of the bridge to the + leg of the cap to make sure they are all connected.
                      • capted
                        • Feb 2011
                        • 30
                        I think the path is good to the cap from the bridge.. What damage can I do if I take the cap out and check the bridge and the voltage to the cap socket?
                        I also should mention this power board is out of the chassis and no other boards are connected( I did get the same reading with all connected)
                          Right now the bridge is not seeing the cap through the isolation diode to charge up the cap to the peak of the sine wave, the isolation diode is good, some time something so simple can cause the problem that is why it is important to check everything. You can run board by itself without another board attached but I will not do without the cap attached since you do not want the AC to be fed to the circuit. You can just jump another cap in parallel with the old cap, it does not have to be big value, 47uF 450VDC will be fine. By the way, are you seeing 60VDC on that large cap right now?
                          Can I see the pictures of the board, both sides.
                          • capted
                            • Feb 2011
                            • 30
                            If the cap was open would it be the same as the cap not being there? I will get some pics up. I did not know you can jump another cap in parallel!!!! What if I use the same size cap uf and volts??
                            • capted
                              • Feb 2011
                              • 30
                              The old brown kxg type one.. I have known good ones I could remove from other spare boards I have.
                                Yes you can jump the caps in parallel. I cannot wait to see what you find out!
                                • capted
                                  • Feb 2011
                                  • 30
                                  Have not tried the cap yet. I did see a schematic somewhere on the forum for a pfc voltage booster circuit. Does anybody know where it is? I can't seem to find it again.
                                  • capted
                                    • Feb 2011
                                    • 30
                                    I found the schematic. https://www.badcaps.net/forum/attach...4&d=1344964111
                                    In case anybody needs it!!!
                                      I am the one that posted that sch with the notes explaining how the PS_ON works and turn on the PFC circuits.
                                      • capted
                                        • Feb 2011
                                        • 30
                                        I should have known that!!!! I have not looked at the board yet but I will keep you posted.
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • shovenose
                                          Source for quality stumpy 450v/150uF STGCON cap replacement
                                          by shovenose
                                          I am attempted to replace this capacitor to repair a power supply. I put in a random used NCC KXG 450v/100uF and it worked but it's too tall and skinny to reinstall the heatsink and even if I drill a big hole in the heatsink for the cap it would still be too tall and the power supply will no longer fit in the network switch.
                                          The original cap seems to be 35mm in diameter and maybe 25mm in height. I could probably go up to 30mm in height and be OK.
                                          Thanks for any help with a source for these, I only need one or two, and the cheaper the better. I found some on eBay that...
                                          08-17-2021, 10:47 AM
                                        • SuperAman
                                          PS5 HDMI port diode reading?
                                          by SuperAman
                                          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                          02-03-2024, 10:16 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Fuzzy Fix
                                          0.00 ESR reading on a capacitor
                                          by Fuzzy Fix
                                          Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                                          I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                                          Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                                          07-26-2024, 12:05 AM
