low voltagw on 150uf 450v cap?
  • capted
    • Feb 2011
    • 30
    #41
    Re: low voltagw on 150uf 450v cap?
    Check this out, I did not want to turn it off or unplug it until you wrote back.. I hit the power buttton on and off atleast 20 times with the 2 bulb connectors still connected and it powered on and offf no problem( no backlight still) so, I unplugged it and plugged it back in and nothing ,no power light.. I pulled the connectors off for the bulbs, unplugged it and hit the power button a bunch of times and now it started to light up again..
      When the monitor was working, if it is not connected to the running PC, does the power light turn off or turn Amber?
      • capted
        • Feb 2011
        • 30
        #43
        I do not know, it was handed to me to try to fix. I do alot of pc work and laptop repairs. I have fixed about 48 lcd's and a few tv's. I just like the knowledge when I have problem like this one for next time. I just can't stop!!!!
        The power is still on without the bulbs connected. The last time I pugged the connectors in for the bulbs they came on. Do you think I should do one at a time and restart or all at once. I don't get why the 2 connectors that were plugged in did not light the 2 bulbs(now that you told me each connector is one bulb) I think I will plug it into a pc now when the power light is on and see if it goes amber sleep mode.
        • capted
          • Feb 2011
          • 30
          #44
          Just plugged it to one of my laptops and the power led went amber....
            You can do one bulb at a time to see if it even light up for second, just do it in the dark room, it will go into shutdown but at least you can tell if the bulb is not completely broken. The lamp assembly can have bad wire which will still light up the bulb for second, all you can do right now is to find out if one of the bulb is complete bad or not.
            If you plan to work on more monitors, then you should get one this inverter to test the lamps, it will safe you so much time.
            http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
            By the way, can you give me the P/N as printed on the inverter transformer? We need to find the pinout so we can check the winding resistance.
            • capted
              • Feb 2011
              • 30
              #46
              I have no idea what the deal is.. After you asked me if it went to sleep when a pc was connected it all changed. the light went amber and I plugged the usb port in and my laptop had the extra usb ports from the monitor.. So I did one bulb at at time restarted the monitor and it lit up a for a second and went dim. The big deal is I got the menu all the time even after it went dim(like dead bulbs but the logic board still works) Itried each one, one at a time--same thing. Than I was thinking what you said that it will shut down the bulbs if there was a problem..... plugged in all the bulbs and it works ..It is still on now..I jus dont get it. I am do not want to unplug it and do this all over again. But I know if I do it won't start again.. This time I took pics of it working so you would not think i'm nuts. Is it possible that this thing locks itself out from starting when it has a problem? What if the vga cord was shorted before I Got it??
                I should have asked you if you have in connected to the running PC. If it does not detect video signals from the PC, it will go to sleep, amber light. I am beginning to think that the problem was the cold joints at the AC INLET since it does not have much support on it.
                http://s807.photobucket.com/albums/y...t=DSCF1116.jpg
                • capted
                  • Feb 2011
                  • 30
                  #48
                  The [problem is I had no power light or sleep mode. I did the caps and re-soldered the entire board like the old ben-q's. still no good until you ask'ed about the connection to the pc.. It is still not together. The boards are loose in the case and the lcd is not secure. It's on the floor. I left it unplugged and will try it in the am. If it works I will put all of it back in the case and see if it works....
                  • capted
                    • Feb 2011
                    • 30
                    #49
                    I purchased the 4 bulb inverter for testing bulbs..Great idea.
                    • capted
                      • Feb 2011
                      • 30
                      #50
                      Update!!!! Today I unplugged it (it was working)...Plugged it back in and no good!! I replaced the 120v connector and put some small wires to the hot side and neutral side just to mak sure the copper traces did not break from the connector to the board... Bang it is on now and still on... Just want to keep all updated...
                        It sounds like you need to scrape off some green coating on the copper to expose more copper to solder the connector to.
                        • capted
                          • Feb 2011
                          • 30
                          #52
                          I did, and put 2 wires to connect the circuit.. I don't want to jump the gun, but so far O.K. Now the problem is, was it the caps and solder joints??? Or was it the power input? I might have screwed up the power socket on the bench when I plugged it in with no support for the board..
                          And Thank you for the help.. I will keep you posted as I let "burn in" still not sure if it is fixed.
                          • capted
                            • Feb 2011
                            • 30
                            #53
                            So far still good. Let the p.c. sleep and the mintor wakes up and is working as it should. I wonder if it was a ground,neutral or line circuit that was erratic.. I'm thinking more ground or neutral because I tripped the gfi outlet when I was moving the 120v socket and checking my voltage.
                            • cmlewis89
                              LG 47LB5DF blown power supply board
                              by cmlewis89
                              Hi folks,
                              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                              09-03-2024, 07:50 PM
                            • shovenose
                              Source for quality stumpy 450v/150uF STGCON cap replacement
                              by shovenose
                              I am attempted to replace this capacitor to repair a power supply. I put in a random used NCC KXG 450v/100uF and it worked but it's too tall and skinny to reinstall the heatsink and even if I drill a big hole in the heatsink for the cap it would still be too tall and the power supply will no longer fit in the network switch.
                              The original cap seems to be 35mm in diameter and maybe 25mm in height. I could probably go up to 30mm in height and be OK.
                              Thanks for any help with a source for these, I only need one or two, and the cheaper the better. I found some on eBay that...
                              08-17-2021, 10:47 AM
                            • SuperAman
                              PS5 HDMI port diode reading?
                              by SuperAman
                              I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                              02-03-2024, 10:16 PM
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
                            • Fuzzy Fix
                              0.00 ESR reading on a capacitor
                              by Fuzzy Fix
                              Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                              I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                              Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                              07-26-2024, 12:05 AM
