KDS 17" LCD
+ More Options
Posts
  • NDJeff
    • Mar 2006
    • 8
    KDS 17" LCD
    I have a couple of these that I brought home from work. They would no longer power up and are beyond the 1 year full warranty period. From a corporate standpoint I guess it makes more sense to replace these than to repair them, even if parts are covered. New ones have gotten cheap enough by now. When I took them apart I found a whole group of bad caps, some bulging, on the power supply board. All 6 of them are the same, 470uF 25v Xunda brand
    I am not real experienced with electronics, but I know some basic theory since I used to work as an industrial construction electrician. My electronic repair expertise is mostly "replace the burnt shit and hope it works ;p" . Anyhow, I temporarily replaced the bad caps with some salvaged ones from junked mobos and the monitor powered up and seemed to work fine However the caps were not the same rating as the ones I replaced, and note even all the same values, so only ran it for a couple of minutes before shutting it down. I have a couple of questions:
    1) When I powered up there was a high pitched squeal coming from somewhere on the board, couldnt tell what component it was. Almost sounded like air leaking, and tapered off like letting the air out of a baloon when I removed power. Another cap failing, inductor, transformer, which is the likely culprit and should I be concerned? Or is it likely a product of my mismatched testing caps?
    2) I ordered Chemicon KZE caps from Digikey for replacements. Since I have the potential of getting more fixable monitors I ordered some extras. Are these OK for this application?
    At any rate, I should get my caps quickly as I am only 150 miles from Digikey I am knocking on wood that caps are the only problem with these monitors, and hoping for more hehe.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: KDS 17" LCD
    KZE look ok
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Re: KDS 17" LCD
      Wait until installing the appropriate caps to chase down the squealing noise. It's likely a transformer or something, though.... sometimes a dab of hot glue on the coils will make them quiet down.
      Ludicrous gibs!
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
        EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
        by momaka
        I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
        So, here is the...
        06-06-2020, 04:39 PM
