Westinghouse L2410nm Buzzing?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Westinghouse L2410nm Buzzing?
    Originally posted by Silviyius
    monitors generally don't buzz.
    I've owned three that buzzed to various degrees, and seen plenty more. It's in no way rare. And it's pretty annoying if you have nothing else to mask the sound, because unlike the sound of a computer fan for example, it's a distracting whine.
    A working TV? How boring!
    • Silviyius
      • 29
      • US
      I guess i've been lucky. I've owned a lot of lcd's. the only ones i've had buzz are crt monitors.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        You must have very quiet computers then. The only time I can hear my CRTs buzz is if I actually put my head against their back where the flyback transformer is. Otherwise, I can't hear them buzz. Some of them do like to whine every once in a while, though - especially at 75 Hz.
        I also have 1 LCD that whines quite a bit. It was really loud after I recapped it several years ago, but now it's much better. I only use it for testing, though.
        • Flaku_34
          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
          by Flaku_34
          Introduction:
          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
          04-18-2024, 12:47 PM
        • dcbw
          PowerMac G5 ACBel 614-0303 buzzing
          by dcbw
          The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
          The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
          Other info: API2FS34, ID 291, Date B0404
          05-31-2024, 07:13 AM
        • Romanio0089
          ASUS UX31A won't start. Black screen, no LEDs, buzzing sound coming from motherboard.
          by Romanio0089
          Hello, I need some help here.
          My ASUS UX31A won't start anymore after a fan cleaning session. At first, after reassembly, there were the power LED, F2 LED, and Caps Lock LED all lighted up but with a black screen. Now, it became worse, black screen, no LEDs, and a strange buzzing sound coming from the motherboard when AC adapter is plugged in. AC adapter LED is green and sometimes, is orange but if I unplug it and plug it back, it becomes green again.. I tried all troubleshooting I could find on internet.
          Here's what I did yet :
          · Electrical discharge - unplugged...
          04-12-2020, 03:30 PM
        • heathloder
          Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
          by heathloder
          I have a Sony XBR-65X850E that won't power on, and has no status lights.
          Immediately upon plugging in the TV, it tries to power up (before pressing anything). I can tell because after plugging the TV in, the main transformer on the power board begins buzzing, 2 seconds on, 2 seconds off, and it does this exactly 7 times before the TV goes back to an “OFF” state. If I press the power button on the TV, the same cycle repeats. I can confirm that no ‘status' LED's are lighting up when this happens. The backlights also do not turn on, but I can confirm that they at least “light...
          04-04-2020, 07:36 PM
        • stvhop
          HP1955L Buzzing noise & interference
          by stvhop
          Hello, This is my first post so please forgive me if I miss out some vital info.
          I have a problem with my HP1955L monitor from 2005.
          The first thing to say is that it is still basically working, ie the picture is fine.
          However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
          The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
          11-07-2020, 07:13 AM
