Hi to all, I'm Emanuele, from Italy. first of all i want to say i found this forum absolutely amazing
I immediately explain my problem. I was reading in this forum some posts about the Acer AL2416w because i was trying to repair the mine and i was doing some measurements with my DMM on the power supply board to test if it was all ok.
...but because i'm a noob i made the stupid mistake of try to measure the voltage across the pins 2-3 of the K3568. The result was that my ups restarted so i thought that i broke some components.
Effectively the fuse F1 results bad (made continuity test) and obviously if before i measured 305 volt vdc across the main capacitor 450v/100uf now i measure 0. so i think that the component k3568 went bad (and i dont know if and/or what others components). so my question is..
do you think i can repair the board and then proceed to the inverter and repair finally the monitor or i must throw all away? I hope someone can help me!
PS: i attached a photo of the board with the components' indications as you can see. the board in photo is not exactly the mine one (i found that photo in another post and modified it because i dont have a good camera) but it's exactly the same board.
PPS: sorry if my english is bad! :/
