ENVISION EN9410e 19" Monitor Bad Caps
  • florida9
    • Sep 2012
    okay so i have repaired a few monitors before so i am familiar with soldiering and disassembling them anyways i just picked up this Envision EN9410e Monitor out of the garbage plugged it in and the screen turns on and off every few seconds so i took it apart and replaced 3 bad caps that i found now it turns on for like 3 seconds and goes black i can still see the desktop if i get a flashlight but its really hard anyways any help is appreciated
    Re: ENVISION EN9410e 19" Monitor Bad Caps
    Please read this: https://www.badcaps.net/forum/showthread.php?t=10419
    and post good clear pictures using GO ADVANCED/ATTACHMENT function to post the pictures.
    • black6host
      Replacement caps for Samson Resolv studio monitor 65A Amp board.
      by black6host
      Good day!
      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
      I'm going to replace the caps and I'll be the first...
      02-06-2024, 08:22 PM
      by momaka
      03-15-2023, 10:17 PM
      by momaka
      03-12-2025, 03:42 PM
      Westinghouse L2210NW LCD monitor - bad caps repair
      by momaka
      Here's another LCD monitor repair: Westinghouse L2210NW.
      Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
      I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
      Pictures of the monitor outside/case after a brief...
      01-11-2021, 01:14 AM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
