Acer AL1914 - No power light, Some screen activity
  • JoeyJoe
    • Sep 2012
    • 76
    First post here. I read about someone else who had a similar problem with their acer AL1914 screen, and fixed it with some help from here.
    The problem I have is slightly different.
    Connected the screen with power lead and VGA lead, Push power button, No light on the power button, and no back light on the screen. Looking carefully with the sun on the screen, it does a washy sort of effect, as if it got some power but turned off again.
    It does this every time the power button is pressed (after waiting a couple of seconds in between presses).
    I currently have the screen dismantled, with the power board in hand ready with a voltmeter.
    What should I check first?
    thanks!
  • JoeyJoe
    • Sep 2012
    • 76
    Re: Acer AL1914 - No power light, Some screen activity
    I have read though some other posts, and found that most monitors insides are practically the same.
    There are 2 Hermei 16V 1000uf capacitors that the top is like a dome shape and pushed up. I suppose blown?
    I have some spare 2000uf capacitors.. would these work as a replacement?
    • JoeyJoe
      • Sep 2012
      • 76
      Impatient me has already connected the replacement capacitor.
      I noticed the blown ones were in parallel with each other. So I replaced them both with a single 2000uf 16V capacitor, and I now have a power light!
      Screen looks to be doing the same though, but will test with something connected to it now.
      Update:
      Connected it to a laptop, and the backlight of the screen powers on for a second, then turns off. the power light remains on. Looks like that was the problem, but it doesnt like the replacement capacitors.
      • sabre504
        • May 2010
        • 449
        Hi the caps you have used are way out on uf you can up or down 20%
        Ie 820uf or 1200uf and should be low esr .
        You can use a larger voltage 25v depending on space
        Also you should replace all the caps on the board with the exception of the larger cap ,a picture of the back and front of your power board will help so test points can be pointed out
        • JoeyJoe
          • Sep 2012
          • 76
          Well I figured that since the 2 caps were next to each other on the same tracks, I would replace both with a single one.
          The screen now works fine, (I forgot to connect the screen wire back into the screen!).
          Bought the screen from a bootsale for £7 from a guy who was packing up his stall... Said it was working. At least I fixed it without paying a penny!!
          • JoeyJoe
            • Sep 2012
            • 76
            On a side note, The monitor is very bright and clear. Looks like when your monitor starts to go dark, these things are on their way out.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Rav_tangle
              MacBook Pro 2011 turns on with keyboard light , screen dead
              by Rav_tangle
              Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
              I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
              Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
              is this...
              05-31-2024, 04:09 PM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Ihandyrepair
              sony 55X850D black screen no front white or red led light.
              by Ihandyrepair
              Hi guys
              strange one
              I have a dead Sony 55X850D
              when plug in, black screen, no front white or red LED, no back light no screen
              Voltages I get
              3.3v LD/power and main board
              reg 12V
              reg 19V
              3.3v on power on pin
              no Tcon on
              no tcon 12v
              no BL_on
              I do get BL_ERR 2.0v
              I tried to bypass it by ground it but still get same symptom
              I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
              or is possible the chip next to...
              08-07-2024, 04:58 AM
