Hannspree HF289H With Unstable Picture
  • zzazz
    • Aug 2012
    • america
    Hey all,
    I have a Hannspree HF289H monitor that started acting strangely a few days ago.
    Regardless of the screen resolution, refresh rate or input used (hdmi, VGA), every 1-3 minutes the image will roll vertically for a few seconds. It reminds me of an old VHS tape.
    I have also seen the upper corner of the screen turn white and spread outward, then just as suddenly the color will revert to normal.
    The logic board and power supply looked fine, no bulged capacitors. What could be causing these issues?
    Any help is appreciated, Thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Hannspree HF289H With Unstable Picture
    Post clear focused top down pictures of all your boards following my sig file below exactly. We want the picture compositions like so
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • zzazz
      • Aug 2012
      • america
      Here are the pictures, thanks.
      • jetadm123
        • 2169
        On your third photo of the logic board, with the power supply connected to the logic board, try measuring the DC voltage output of the voltage regulators. They appear to be U103, U101, U102 and U901? (to the right of U102). Use a mounting screw as your ground and measure the legs and tab of each regulator. Report your readings along with the part number of each regulator.
        • retiredcaps
          • Apr 2010
          • 9271
          Originally posted by jetadm123
          OReport your readings along with the part number of each regulator.
          Like jetadm123 says, report them like so along with the part number (include all lines on the IC) of the IC. For example,
          U100
          AS1117-33
          pin 1 = 0.0
          pin 2 = 3.3
          pin 3 = 5.0
          • zzazz
            • Aug 2012
            • america
            Here are the voltage readings, part number in italics.
            U101
            80e
            17-18L
            pin 1 = 0
            pin 2 = 1.8
            pin 3 = 3.2
            U102
            1084
            0809nL
            pin 1 = 2.4
            pin 2 = 3.6
            pin 3 = 5.1
            U103
            1084-33
            0813LL
            pin 1 = 0
            pin 2 = 3.2
            pin 3 = 4.8
            U904
            8cL
            1117L
            pin 1 = 0
            pin 2 = 0
            pin 3 = 0
            • jetadm123
              • 2169
              You might want to measure U904 again as you seem to have no input voltage to the regulator.
              • retiredcaps
                • Apr 2010
                • 9271
                Also, unless you have an analog multimeter, report all the numbers on the multimeter.
                A regulator that measures 3.2 implies 3.20 which means it is bad (out of specification). However, if the real reading is 3.29, then report it as 3.29.
                  This sounds a lot like a loose LVDS cable, especially the fade to white. Try reseating the cable going from the main board to the board at the top of the LCD.
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                    I ordered a supposedly β€˜new' Tcon board this time, and
                    06-09-2024, 10:28 AM
                  • CyberPhoenix
                    Issue with picture quality of Sony bravia TV
                    by CyberPhoenix
                    Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                    01-22-2024, 02:08 AM
