image is ok but black Rectangule [M713-S3]
  • strelok
    • Aug 2012
    • 7
    • france
    hi everybody
    I have done a DIY videoprojector with a base of a packard bell sreen,
    I'm using an ATX alimentation of a pc, (+12, +5, GND) and the signals BLON & BRI are tied to the ground.
    The image is fine on the screen but there is a big black rectangle in... what could be the source of it?
    I can see a cms component that could be a fuse, shoult I shunt it?
    (pix are comming)
    thank you very much
    (I apologize for my english, I'm french )
  • strelok
    • Aug 2012
    • 7
    • france
    Re: image is ok but black Rectangule [M713-S3]
    I have check every cable of the ribbon between the card and the sreen and all seems to be ok (with a ohm-meter) but
    the blue stripe was black witch one staight line of blue, green and red
      My guess is during the removal of the LCD you damaged those bonds at the top of the screen. It would be difficult to fix.
      • strelok
        • Aug 2012
        • 7
        • france
        thanks
        so for you if it's working like "half" the card is not broken?
        The faulty cable is the one card-lcd or computer-card?
          Originally posted by strelok
          thanks
          It is those little brown ribbons at the top of the LCD screen itself, and the damage is unlikely to be repairable.
          • strelok
            • Aug 2012
            • 7
            • france
            ouch...
              You can try applying a little pressure to them, seeing if the picture improves or changes.
              • strelok
                • Aug 2012
                • 7
                • france
                the picture change when I touch the gold plated pins near the rectangle but this is a slide to the left of the good right stripe
                • strelok
                  • Aug 2012
                  • 7
                  • france
                  I think that is not when i disasemble the screen that I broke something becouse it was working fine some days ago
                  could it be another ribon who is wrong?
                  • selldoor
                    Slow Learner
                    • 7870
                    It was on and working - you switched it off and next time on it was black?
                    Without moving or changing anything?
                    • strelok
                      • Aug 2012
                      • 7
                      • france
                      yes, 2 weeks unpowered and since 2 it doesn"t work
                      • selldoor
                        Slow Learner
                        • 7870
                        Try reseating the cables again -if a flat ribbon to the panel clean and reseat.
                        Check the cable from the pc -is it ok on another screen.
                        • Ancient1
                          Strange LG TV issue : Image vertical lines in black screen
                          by Ancient1
                          Hi
                          Asking for a friend.
                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                          but here its the opposite !
                          TV has new T-con = same issue
                          A missing panel voltage would have global effect
                          So , what should one do ? how can I find where the fault is ?
                          Thanks !...
                          02-05-2025, 03:37 PM
                        • cjard
                          Dell U27HM flickering/quarter image/black with smeared colors
                          by cjard
                          Hi all
                          Wondering if I could get some insight on a Dell U27HM. First turned it on and the image was completely black. I later realised that if I dragged a window from one monitor to (the broken) other one then smeared colors would appear on the bottom 75% of the screen. After being on for several hours the top part of the screen started flickering showing an image (I have a video of this) and then suddenly the image appeared albeit rather fuzzy in the bottom 75% - image attached - and some hour later it now appears normal
                          I do have two of these monitors so a compare/swap...
                          09-13-2022, 07:12 AM
                          MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                          This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          09-12-2024, 01:58 PM
                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-07-2024, 05:00 AM
                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 04:10 AM
