Westinghouse L2610NW 26" 16:10 LCD backlite problems
    Re: Westinghouse L2610NW 26" 16:10 LCD backlite problems
    Yes. That was the origonal problem. When I went to try momaka's post #2 idea.
    I stated in post #5 that now no backlite, not even a flash.
    Thanks for helping with this.
      There are 4 fuses on the board if the power light comes on the first one by the power supply connector should be ok but can you test the other 3. FS2 FS3 & FS4
        Never was a problem with to pwr lite.
        FS2 and FS3 .3ohms FS4 .4 ohms.
        Just to be sure,with my 8" magnifer CFL lite again checked all solder joints and components = good, as I can see.
        Going further, remover the Signal PCB, barcode; 26J1LR2000 M$35-D019965-L-$HTR7423000LH nice build with a metal cap.
        also the Display barcode; CHI MEI optoelectronics corp. model A260J1 M$44-D018925-L$C11111G117X30341
        Thinking I should learn how to take apart to check CCFL's..
        No fun not being able to isolate yet.
          So no ccfl testing req. Found a inverter PCB FS.
          Runs cooler than orig. at 1920x1200
          Still would like to fix it.
          Post back when.
            So a new inverter board fixed this? And do you have links to where you got it? Would be nice to have in case someone searches for it.
              Got from shopjimmy.com
              I need to rejoin nesda
              PCB Has Different Inverters, are AS XEA-517430-25960-D 0746
              Is running way cooler than orig.
              Found Chimei Innolux has a LA office Awating reply.
