Dell 2407 WFPb won't stay in sleep mode
  • entrant
    • Jul 2012
    My Dell 2407 WFPb won't stay in sleep mode when my laptop goes to sleep, even though the Dell did it until recently. "Entering sleep mode" flashes briefly, but than the Dell switches back to power-on mode, except the message "DVI-D cable not plugged in" now bounces around the screen. The DVI cable is plugged in at all times: it's a HDMI-DVI connector which worked fine as far as sleep mode until recently. I replaced all the caps on the Dell's power supply board just in case, but it didn't fix the problem (the monitor works OK otherwise, so I didn't break anything by replacing the caps). What else should I try? I don't want to discard the monitor just yet. I wonder if it may have something to do with Win drivers for the card (NVIDIA GeForce GT 230M, Win7 64). However, I don't think Win drivers can affect the card outside of Win, whereas the "DVI cable not plugged in" message flashes even at BIOS boot time, ie. before Win had a chance to load.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    The SKU is in brackets (****)
    EDIT: NVM65...
    01-26-2025, 06:22 AM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
