lg w2234s
  • ketan patel
    • Jun 2012
    • canada
    lg w2234s
    I replaced capacitor.didnot solve problem,everytime after 2 second lg logo.i try replace chip on mainboard( inverter ) board. solder pad came out,anybody have ckt. for soldering point.
    mainboard # H7901501300600r, I need pin layout for u108 ic
  • retiredcaps
    • Apr 2010
    • 9271
    Re: lg w2234s
    It is your lucky day. I have this exact board and have the exact same problem with the 2 second logo, reboot, over and over. As you discovered, the code in U108 is likely corrupt.
    I ordered a replacement off ebay, but it didn't fix the problem. However, I may have gotten a bad part so I'm willing to try again.
    While I have no schematic, I can ohm out the IC using my multimeter. Which pins did you lift?
    --- begin sig file ---
    --- end sig file ---
    • Mirenia
      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
      by Mirenia
      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
      03-30-2025, 06:47 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • Devonavar
      Vizio M43-C1 - How closely do I need to match the mainboard number?
      by Devonavar
      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
      So, I've ruled out the PSU for now.
      The reboot loop...
      08-14-2022, 08:46 PM
    • Malva
      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
      by Malva
      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
      Mainboard model: EAX65684604
      PCB marking: EBT62954607
      SPI chip: Winbond W25X20CLNIG Problem description:
      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
      • I bought another
      06-25-2025, 02:07 PM
    • Jembang
      coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
      by Jembang
      good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
      11-01-2024, 09:55 AM
