HP w2207 hissing sound flickering
  • dobi
    • Oct 2010
    • 26
    Hi to all
    I just picked up a hpw2207 from CL and it was posted as not getting out of sleep mode. I took it home and connected it and it seems to work fine. I rebootet a few times, turned it on and off and the only two problems I have is a hissing sound when turning booting or shutting down and sometimes it flickers before the picture shows up.
    Could that just be a bad connection?
    I am not a electronic guy but pretty handy with everything.
    Someone has any ideas?
    Markus
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP w2207 hissing sound flickering
    Originally posted by dobi
    Hi to all
    I picked up one these about 2 years ago. It wouldn't turn on and made a screeching noise while trying to turn on. I opened it up, found bad caps, replaced them with Rubycons, and now use it as my "main" monitor.
    You probably have the same problem.
    PS. Caps don't have to bloat to be bad. From the description of not coming out of sleep mode, it sounds like the caps have high ESR. As the monitor warms up the ESR drops and allows the lcd to function.
    --- begin sig file ---
    --- end sig file ---
    • dobi
      • Oct 2010
      • 26
      Thanks for the quick reply. I just tried to turn that thing on and nothing. Blue light on power button keeps blinking, but nothing else. Was interesting that it turned on when i got it home, connected it and it turned on after a while. Guess I have to google how to take that thing apart. I am right that you want me to look at the psu? Are there any service manuals for this monitor?
      Markus
      • Rtech
        • Jul 2010
        • 1095
        The exterior looks very similar to the W1907.These have a very good Power Supply,and 95% of faults I have seen,were caused by failure of the return wiring on the top pair of Backlights,or the Backlights themselves.The channel on the 1907 holding the lamps is the narrowest I have seen for two lamps,and with heat rising,poor quality wire,and poor solder joints,I would certainly bear this in mind looking at your Monitor,just in case.
          It may be almost the same as 2208:
          http://s807.photobucket.com/albums/y...ell%202208WFP/
          http://s807.photobucket.com/albums/y...ll%202208WFPF/
          • dobi
            • Oct 2010
            • 26
            Thanks. The previous owner tried to fix it and almost burned up the board around one of the ceramic capacitors around the high voltage connectors for the backliht. Fixed that with a smaller solid wire.
            But the main problem was 2 dead caps. 1000uf 16v i thing. got two from a local audio repair guy. one was a 1000uf 35v and the other was a 1200uf 25v. after changing them it works fine. nice bright picture and no problems at all.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:30 PM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
