Lg flatron w2252tq-pf
    Re: Lg flatron w2252tq-pf
    the missing voltage on the pin2 of Q1 is ground, sorry didnt check that sooner,
    voltage testing on lvds connector on the tcon board:
    PIN VOLTAGE
    1 GROUND
    2 1.1
    3 1.1
    4 1.1
    5 1.1
    6 1.1
    7 1.1
    8 GROUND
    9 1.1
    10 1.1
    11 1.1
    12 1.1
    13 1.1
    14 1.1
    15 GROUND
    16 1.1
    17 1.1
    18 GROUND
    19 1.1
    20 1.1
    21 1.1
    22 1.1
    23 1.1
    24 1.1
    25 GROUND
    26 3.3
    27 3.3
    28 1.6
    29 4.9
    30 4.9
    31 4.9
    32 GROUND
    taken from the tcon specs:
    Pin No Symbol Description
    1 RXO0- Minus signal of 1st channel 0 (LVDS)
    2 RXO0+ Plus signal of 1st channel 0 (LVDS)
    3 RXO1- Minus signal of 1st channel 1 (LVDS)
    4 RXO1+ Plus signal of 1st channel 1 (LVDS)
    5 RXO2- Minus signal of 1st channel 2 (LVDS)
    6 RXO2+ Plus signal of 1st channel 2 (LVDS)
    7 GND Ground
    8 RXOCRXOC+ Minus signal of 1st clock channel (LVDS)
    9 RXO3- Plus signal of 1st clock channel (LVDS)
    10 RXO3+ Minus signal of 1st channel 3 (LVDS)
    11 RXE0- Plus signal of 1st channel 3 (LVDS)
    12 RXE0+ Minus signal of 2nd channel 0 (LVDS)
    13 GND Plus signal of 2nd channel 0 (LVDS)
    14 RXE1- Ground
    15 RXE1+ Minus signal of 2nd channel 1 (LVDS)
    16 GND Plus signal of 2nd channel 1 (LVDS)
    17 RXE2- Ground
    18 RXE2+ Minus signal of 2nd channel 2 (LVDS)
    19 RXECRXEC+ Plus signal of 2nd channel 2 (LVDS)
    20 RXE3- Minus signal of 2nd clock channel (LVDS)
    21 RXE3+ Plus signal of 2nd clock channel (LVDS)
    22 GND Minus signal of 2nd channel 3 (LVDS)
    23 NC Plus signal of 2nd channel 3 (LVDS)
    24 NC Ground
    25 PWM_OUT No Connection (For LCD internal use only.)
    26 VLCD No Connection (For LCD internal use only.)
    27 VLCD Reference signal for burst frequency inverter control
    28 VLCD Power Supply (5.0V)
    29 RXO0- Power Supply (5.0V)
    30 RXO0+ Power Supply (5.0V)
    if no other ideas will come up i'll give up on this monitor
    repair too much time and effort,
    BUT i'm not regreting i've learned a lot!!
      i got a replacment panel yesterday, found a screen with broken logic board
      and now the image is perfect.
      good thing i havent tossed it away.
        So, in short:
        "Blurriness" and distortion were caused by bad TCON, on this model LCD panel the TCON is not replacable?
        The same panel is used in my defective device, an LG TV, 22LG30
          you have the same problems as i had?
          i tried my best but found no solution but replacing the panel,
          to your question, the tcon board is connected to the panel with ribbon cables that are
          glued/soldiered on the board that cannot be opened.
            Correct, my display is exhibiting the same symptoms as your monitor, However it's an identical LCD panel in a TV package instead of computer display.
