Belinea Model: 10 17 10
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Got this LCD for almost nothing, knowing it was not working
    When it is turned on, monitor cable not connected to PC it comes up with 3 horizontal split sections in white grey/black-ish and white, the grey/black-ish fades to white(er) before the monitor cuts power.
    The upper secion has some "noise" or black/blue small lines that also fades (to white)
    When the monitor cuts power the LED switches from green to yellow (standby)
    The +3.3v & 5v are stable (untill the monitor cuts power) 3.297v & 5.000v respectivley.
    +12v is first at 14.1 for a brief period, then 12.26v next it spikes up but goes back to 12.26v and after a few more seconds power is cut...
    If I remove all cables from the main PCB except the powersupply cable, and cable going to the front PCB with powerbutton the issue is still the same, i.e. without lamps and stuff even being on it cuts power and spikes the +12v in the same manner
    So therefore I am assuming the powersupply is faulty and need some help in diagnosing it, it has a 10 pin connector with power outputs, in this order:
    Code:
    +3.3v
    <empty>
    +12v
    +12v
    GND
    GND
    +5v
    +5v-fix
    GND
    P-Saving
    Volume-C
    5v-fix as the name implies always has 5v standby power, for soft power-on...
    P-Saving reads 2.880v and Volume-C: 0.770v
    During all this testing (I had to turn on and off the monitor for every reading) it twice stayed on, then the picture was 100% white with what looked like a trinitron line straight across the screen at 1/3 from the top, and that part was also visibly "different" from the white below, can't describe it better than that... Also the +12v reading was stable at 12.26v then...
    Everything on the PCB looks fine, the caps are all Lelon RGA except for 2x RXJ and one small TEAPO, the bulkcap is of unknown make
    All PCBs has the text "Acer Peripherals" written on them...
    Can I test the PSU by shorting +5v-fix to Ground and connecting a PC harddrive as ballast to +12v and +5v? Or how do I turn on the PSU on it's own?
    EDIT; and learned the hard way that the heatsink with the single mosfet holds 120VAC; touched it with my underarm when probing with the DMM Fortunantley the power stayed in my arm and did not travel to the other arm where I had my antistatic wrist strap connected (that is like last time I got shocked by a PSU...)
  • starfury1
    • May 2006
    • 1256
    Re: Belinea Model: 10 17 10
    Hi Per Hansson
    Guess you are probably looking for the definitive answer on this but I am no guru on tft's
    (worked on a few but not on a day to day basis)
    If it is the power supply and you dont have a schematic, I would track down info on that big chip.
    There is a cap that may be bulgding slightly behind it, bit hard to tell from the photos
    May be worth checking it out
    (could be the problem or symtom of the problem)
    Since it has acer stamped all over it it may infact be a rebaged acer
    (but I am not sure who makes what these days)
    OK hope someone who works with these thing on a daily basis can give much better advice then I
    BTW its a worry to hear you are trying to become "1 with the Light Bulb"....BE Careful
    Live switch modes and wrist straps ??????
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Well, I first need help to test the PSU, I think it might be faulty but I do not know... So I need to know how to send it the "power on signal"
      All the caps look visually fine, both the tops and bungs looks good, of course that could still mean problems since the caps are Lelon and could have failed silently...
      The big chip, it is a "ST TDA7496" Which is a "5W+5W AMPLIFIER WITH DC VOLUME CONTROL" i.e. it is the chip which drives the two built in speakers...
      Haha, yea, I always advice (on these forums to) to not wear a grounding strap when working on powersupplies, but we all known to not work as we teach right?
      • Rainbow
        • Aug 2005
        • 1371
        I'd disconnect the built-in power supply and connect an ATX one - to test if only the power supply is bad and the rest of the electronics work.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I was thinking of doing that, but will it be ok to just ignore that P-Saving line at 2.880v?
          I.e. only connecting up +5VSB, +5v, +3.3v and 12v?
          • starfury1
            • May 2006
            • 1256
            Doh!
            had I had looked at the overview pick more closely I would have seen it was connected to the speakers, still really wasn't expecting to see the Audio amp ic on the psu pcb.
            ( I was busy looking at the pcb close up pics)
            Seems all the action happens on the under side,
            As to the supply...I would lightly resistive load on the rails and I suspect the pwr switch is a momentary type switch that causes a flip flop type action to happen
            I would mimic the switch , but again no expert and purely guess work on my part
            I've been shaking the net to see if anything falls out but nothing of any help
            • starfury1
              • May 2006
              • 1256
              Rainbow sugestion would be what Id have tried if it were straight power connection but I am wondering what the interaction is if any.
              Like is that main pcb telling the psu to shut down because of a fault
              depends I suppose on how p,save line works...and that I don't know
              I am guessing you would get away with a quick power up test but its not mine to risk
              Id rather be sure then sorry....thats the nice thing about have a few of the same type about, you can play board jockey and see which one the problem pcb Oh well (and hopefully not blow up a working PCB)
              Really wish I could be of more help to you Per H
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Anyone else have anything to say about testing the monitor with a normal PC PSU?
                I'm a bit weary of trying it...
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Well, finally tested with a normal PC PSU, the issue was the same, the monitor powered up just fine like before with 3 section of black and white then it cut power to the LCD, of course it could not turn off the powersupply but that did not seem to matter...
                  So I guess the culprit must be that large main PCB which everything connects to, because as I said before it still turned off with nothing else connected to itself (i.e. without the cable going to the PCB the lamps are connected to and the other two cables leading into the monitor itself)
                  • arneson
                    • Sep 2005
                    • 1267
                    Per, I also buy these cheap, but I look for two at a time when I get them.
                    One with blown main board and one with smashed screen.
                    Then as star said I use best of each and chuck the rest.
                    Jim
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      What are the ratings of these capacitors? (pic is of the main PCB which I think is the culprit...)
                      Is the top number the uF rating and the middle the voltage rating?
                      • japlytic
                        • Oct 2005
                        • 2086
                        Yes, the top number is the capacitance and the middle number is the voltage.
                        Apparently, depending on the application, SMD capacitors are more likely to fail than their leaded counterparts.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Ok, but what's up with that cap in the middle? Reads:
                          08
                          68
                          25x
                          • Rainbow
                            • Aug 2005
                            • 1371
                            Probably 68uF/25V
                            • japlytic
                              • Oct 2005
                              • 2086
                              Yes, it is 68uF, 25V.
                              (Beware of decimal points which can be hard to see)
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                I've ordered some caps from Elfa, lets see how this goes...
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  Installed all the new caps, surface mont caps where really easy to work with, kinda wishing mobos would use them instead... Much less hassle to remove and no cleaning of holes needed of course ;-)
                                  But when I turned the thing on the issue was the same as before I.e. I get a couple sections of the screen in black/white and then it shuts down... And I also previously tested with both another powersupply (PC ATX PSU) and without the lamps and other stuff connected so I am sure that the issue is with this "main" PCB...
                                  Anyone have any idea as to what could cause this type of failure mode?
                                    by momaka
                                    03-15-2023, 10:17 PM
                                  • wattage
                                    AOC AG493UCX 49-inch monitor - Firmware request
                                    by wattage
                                    Hello Badcaps Community,
                                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                    07-13-2025, 04:41 PM
                                    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-06-2024, 07:46 AM
                                    MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                    09-06-2024, 07:29 AM
                                    MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 07:25 AM
